Freezers Logo
Brenda Weatherholt Posted on Jun 12, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is controller knob on freezer - Haier Freezers
  • Bernard Fallon
    Bernard Fallon Jun 13, 2016
    Inside on the right side near the door hinge
L Pfaff
Level 3:
Top Expert:
  • Haier Master 11,573 Answers
  • Posted on Jun 12, 2016
L Pfaff
Haier Master
Level 3:
Top Expert:
Answers
11573
Questions
0
Helped
3587509
Points
181713
Brenda, haier freezer control quite often front lower right corner, some may be behind freezer by compressor, check the links to see if you can find your model and manual. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://image.haier.com/manual/southeastasia/haier/freezer/chestfreezer/201203/P020120309357074931017.pdf
Haier Freezer manuals
Haier Freezer controls Google Search
Where is adjustable cold control on kenmore model 15098 freezer
Found this
The temperature is factory preset to provide satisfactory food storage temperatures. However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. If a colder temperature is desired, turn the temperature control knob toward MAX and allow several hours for temperatures to stabilize between adjustments.
In my experience, the temperature adjustment knob is behind the grill on the side. They put it hidden there because you hardly ever need to touch it. The model number isn't quite right for a Kenmore. It should be 3+5 numbers 123.12345 like this one 253.12502
https://i.sears.com/s/d/pdf/mp-tc/spinpdf/spin_prod_1011956212
Where is the temperature control knob on Frigidaire upright freezer model #CFFH17F1RW
The temperature control is located inside the freezer on upright models, and onthe left outside wall on chest models. The temperature is factory preset to providesatisfactory food storage temperatures.
However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. If acolder temperature is desired, turn the temperature control knob toward COLD-EST and allow several hours for temperatures to stabilize between adjustments
Where is the control knob for Frigidaire upright freezer Model No FFU20FC4AW2
It is on the back wall, about 2/3 of the way to the floor on the right hand side... Knob will look like this: Frigidaire Freezer Control Knob 216707200
You probably have food in front of it!
Frigidaire upright FFU17f9gw3 temperture light is on and food is starting to thaw. I put alot of freezer jam in freezer yesterday
If the control is "ON" and the compressor is not running, you will need a start relay... Make sure you didn't accidentally turn it off by pushing food against the control knob!
Cant find temperature control knob
Good Afternoon Friend,
I understand that you are looking for the temperature control knob on your Frigidaire freezer, model# FFU2064DW. The temperature control is located inside your freezer on upright models, and on the left outside wall on chest models. The temperature is factory preset to provide satisfactory food storage temperatures. However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. Hope this is helpful.
-Best Regards-
WP
True T-49 refrigerator/freezer temperature calibration
Contact the manufacture, it is most likely going to be covered under warranty. If the knob is not removable, (check for a set screw on the side of the knob it will take a small allen wrench) Then the thermostat (temp controller) will need to be replaced, if it isn't a style that you can calibrate.
I have " E
E1 - Control board problem
Notes: C, E
C:
Disables clean mode in Thermador device, allows cook and microwave
E:
1. Turn the clock selector knob to OFF
2. "Tweak" the oven control by turning the clock selector knob slightly to the left
(counter clockwise).
This may stop the flashing message/beeping and clear the display window.
Hope helps.
Hi, freezer is cold at bottom , circulating fan is not working.
Hi Guys, I tested fan removed(to 240vlts) neg- pos to wires+earth to mount bracket, and found to be working, reinstalled and found power - active to both wires??fan cut out (defrost mode)activated by timer control, my timer control ( bottom rear near motor) has a knob, so i turned it and fan started,continous turning knob ran thru all cycles defrost,fan start, etc: obviously timer control was faulty, To save frozen goods , i set control to run and installed a power point timer to cycle freezer till new switch arrives, taking the place of faulty controller...
Refrigerator does not get cold
In your freezer section, there should be a "control" for the freezer temp. I say "control" because the knob is attached to a flap that only controls airflow the the lower section. If the knob is turned to coldest it will block almost all of the air from getting into your fresh food section.
Top Haier Freezers Experts
NOEL
NOEL
Rob Hill
Rob Hill
Are you a Haier Freezer Expert? Answer questions, earn points and help others
