Question about LG RH177 DVD Recorder/HDD Recorder
Tracfone Lg 800 sd card has x over it
Trying to transfer pics to sd card when insert card shows x over it, and external memory not highlighted, need to retrieve pics from phone tha is no longer active.
Posted by Sherlyn Comeaux on
Grubhead
  • LG Master
  • 5,700 Answers
X probably means that it can't read the card. Either the card is not compatible or faulty.
Posted on Jun 12, 2016
How to transfer music to tracfone lg 500g
To transfer files to a phone, you can use an android transfer assistant, which allows you to export and import data between phones and computer.
MobiKin Assistant for Android Windows Version
Jun 06, 2017 | LG 500g TracFone
Now i purchased a micro sd card for my g 800 phone i put the card in and i still cant get pic or video on the sd card
Are you sure it's a microSD card, 2GB or smaller? The LG800 won't work with higher-capacity microSDHC cards.
Apr 18, 2013 | LG 800g TripMinutes Touch Screen tracfone...
Transfer pictures from lg501c to computer
You need to download the usb software from lg website.
Feb 28, 2012 | LG KE Cameras
Took pictures on camera without inserting card, no cord
Yes, there is.
Insert the card into the camera. Make sure the storage location is set to internal memory.
Press the Review button, then press the Menu button. Press up/down to highlight Copy, then press OK. Press up/down to highlight an option, then press OK.
Note: this process is actually a copy, not a move. The originals will still be in internal memory. After you transfer the pics to your computer, you can then delete them normally.
To change the storage location, press the Menu button. Press up/down to highlight Image Storage, then press OK. Select Internal Memory and press OK.
Jun 17, 2010 | Kodak EasyShare Z710 Digital Camera
I have the lg vu and I need to transfer my picturesto my computer. How do I do this?
insert a micro sd card into the phone, save all your pictures on the memory card and plug your phone to your computer using a usb cable and it will ask you if you want to transfer your pics to your computer.
May 11, 2010 | Cell Phones
LG banter won't recognize data on SD mirco card
Please try to back up the music and picture that you have on the memory card, try to format the card using the phone before transferring the music and pictures again. Try to consider the memory capacity of the card, make sure that it is compatible with the phone.
Jul 09, 2009 | Cell Phones
My 2GB MicroSD card doesnt work!
Format the micro sd card first and then re-insert . Sometimes the problem can be rectified
Jul 06, 2009 | LG VOYAGER VX10000 Cellular Phone
Lg kf600 sd card
I don't think this is possible with object push. (I think you want to transfer files from your PC?). You can however explore your PC from your phone, select the file and transfer it to your phone. If the sdCard is in your phone you will be asked where to save the file (on the phone or on the external memory).
Hope this helped
bye
Apr 22, 2009 | LG KF600 3MP InteractPad Triband Phone...
LG shine CU720 moving pictures rto memory card.
The LG Shine allows you to do a multiple picture DELETE - but not a multiple pic transfer to memory card, at least that I've found. You have to transfer your pics one at a time from phone memory to the SD card as follows:
Select Menu --> 8 My Stuff --> 4 Pictures
Highlight the pic you want to transfer using the center toggle button,
then select Options --> 5 Move (or 4 Copy) --> 2 Memory Card --> Paste
Once your pics are on the memory card then put the phone into USB mode by selecting
Menu --> 9 Settings --> 7 Connection --> 2 USB Connection Mode --> 2 Mass Storage
Then attach a suitable USB cable to the phone at the charging jack and open Explorer (Windows) or Finder(Mac) and navigate to the phone. Your pictures will appear and you can copy them to your computer as needed.
NOTE: be sure to return the phone from Mass Storage mode to Data Service or your phone will not work.
Also - set your phone to highest resolution for best quality pics.
Menu --> 8 My Stuff --> 7 Camera and Recordings --> 1 Take Photo --> Options --> 4 Resolution --> 1 1600x1200
Mar 22, 2009 | LG Shine CU720 Cellular Phone
Lg shine, transfer taken pics from internal memory to sc memory c
first you need a micro SD card
go to the Camera --> Options --> 1.Photo Gallery --> in the menu, highlight the picture you want to move and select Options --> then there should be choices like Move or Copy --> choose Memory Card
just put the SD card in your computer and copy the files
Jan 13, 2009 | LG Shine KE970 Cellular Phone
LG RH177 DVD Recorder/HDD Recorder Logo
47 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Ekse
