Question about Acer 22" X223w LCD Monitor
Display not working, power button LED turns on blue for 1 second and won't turn on again
I've searched the web as well as this site and can't find my exact issue anywhere. I hope I'm not duplicating this question though. My X223W monitor is pushing 6 years old. It was working perfectly 4 weeks ago before a 1 week trip. When I returned, I pressed the power button to turn it on. The power buttom LED simply turned on blue and then turned off after 1 second. I get NOTHING on the display itself, not even a flicker nor the Acer logo. Pressing the power button again got nothing - not even the 1-second power button light. I unplugged the monitor, plugged it into a wall outlet it was plugged into a power strip the whole week I was gone, tried the power button again, but got NOTHING. Not even the 1 second power button LED. Here is what I have tried to fix this: 1. Tried 3 different power cables that are confirmed working - nothing. 2. Tried 2 different outlets that are also confirmed working - nothing. 3. Tried unplugging the monitor, holding the power button for 10 seconds to do a reset - nothing. Although, this did accomplish restarting the cycle in which I am able to get the power button LED to do its 1 second turn on/off again. Still nothing on the display, though. 4. Took apart the monitor to look at the power supply board capacitors. None of them were blown, bulging, or looking strange at all, but I ordered a kit online to replace them anyway. When done, I triple checked my solder points, cap orientation, uF size of each cap, and re-connection of all cables - all good. But, the symptom is exactly the same. Same 1 second power button LED turning on/off with nothing on the display. Because of the age of the monitor, I think I'll likely just buy a new Acer. But, I'd love to fix this one eventually so that I could maybe end up with two displays. Is there another component I should be looking at that might cause this? Should I replace the entire power board? Is in an inverter? The logic board perhaps? Any advice would be welcome.
Posted by Daniel Grimm on
Intel DESKTOP BOARD D945GPB-Win XP Home Edition OS. All web searches keep crossref. all other boards D945G* or D945G**. No mention of D945GPB anywhere on net or Intel Site.
Boot up computer from being off and press pause key right top hand side of keyboard when the bios number comes up on the screen. Pause boot up and read the bios number that is displayed during the P.O.S.T sequence of your Bios start up.
Then try googling the Bios number to get the exact motherboard involved.
Good luck !
Feb 09, 2017 | Intel Computers & Internet
My Acer X223W auto-aligns my screen 2
I was having this exact same issue. I held down the 'e' button and let it re-auto config and it seemed to clear up the problem.
May 28, 2012 | Acer X223W Monitor
Have a Acer x223w monitor and it fades to white and then fade to black. I looked at the caps and nothing look blown on both boards. When I turn on the monitor the acer pops up and no signal look fine. But...
Have you verified that the problem is indeed your monitor and not the video card on your PC? i would start by connecting the monitor to a laptop or another PC to verify that the same issue occurs no matter what the source. Once you've verified that, you're likely dealing with a monitor that requires repair or replacement. Hopefully it's under warranty. Hope this helps a bit.
Aug 13, 2011 | Acer 22" X223w LCD Monitor
I LOST MY LOGITECH WEBCAM DRIVER N231.M/N:V-UBQ42 P/N:860-000091.PID:-LZ815BP. HOW CAN I INSTTAL? HOW CAN I SEARCH? HOW CAN I DOWNLOAD SOFTWARE?
Is there any way you can be a little more specific. What is the exact model name for this Logitech Web-cam? If you are unsure though you can click here to go to a web site called driverwhiz.com that has a program that once installed searches your PC for any Logitech product and downloads and installs the latest drivers for it.
Please rate this solution by clicking the thumbs up at the top right of this solution. Your rating is much appreciated.
Thanks.
Nov 02, 2010 | Logitech Webcam
All of a sudden X223w ghostly lines and fuzzyness when 1st turned on. Taking longer and longer to clear up. Have had the monitor for about 6 months. A few days ago this problem occurred and lasted for half...
This problem is caused by a defective power supply. The unit is still under warranty so you will need to contact Acer to get it serviced. We web site is www.Acer.com click on the service link and they will set up a return authorization for you. The normal repair time is 7-10 days including shipping times.
I hope this helps, if so please rate our solution.
Buddy
Corporate Compute
www.ccl-la.com
Jan 07, 2010 | Acer 22" X223w LCD Monitor
Have a gateway md2614u laptop. need to change the power coupling on the moterboard. can't seam to detach the cover.all screws and hd, cd, mem, cpufan, are out and screws on vga adpt.
I searched gateway's website but they're pretty tight lipped about their service guides. I did find this link to some pdf files, even though it's not your exact model, you might find some useful info there. Hope this helps and good luck. If I 'fixed ya' please rate me.Thanks.-jmattes ( just copy and paste the link into your browser) http://tim.id.au/laptops/gateway/
Oct 26, 2009 | Gateway MD2614u Notebook
I have a x223w monitor that if you try to set higher than1280 x 768 it stretches eveything horizontally
Does your video-card allow you to set a resolution of 1680 by 1050?
(This is exactly 16 pixels horizontally for each 10 pixels vertically.)
This is the "native" resolution of the X223W monitor.
If not, pick a supported resolution that keeps the 16-to-10 ratio.
Sep 10, 2009 | Acer 22" X223w LCD Monitor
I cant install my web cam coz i lost my installer cd..help!
If you have provided me the Exact Model, it would be easier for me then,
Even though here's what I'v found for you.
Link 1 (Different Logitech Model Drivers)
Link 2 (A pakage of Drivers, usually Latest Models)
LInk 3 (Official Site, Select your Model and Search for the Driver)
Regards,
Waqar.
Aug 18, 2009 | Logitech Webcam
CPA Usage at 100%
There are a number of sites on the web that list tasks that will be listed in your Task Manager and explain what they are. Here is one of the better sites:
http://www.answersthatwork.com/Tasklist_pages/tasklist.htm
If you have tasks not listed there a search should get you another site that will list it. You should check each of your tasks and then decide which ones you can do without.
Aug 09, 2009 | Computers & Internet
"cannot display web page..." when trying to go to www.accessgenealogy.com. I can go anywhere but here and 1 other site. From my internet searches for an answer, it appears thousands if not hundred's of...
Hi peonygirl_56
If it's only a couple of sites you experience this with then it may be the sites that are having the problem and you would need to contact the owners of those sites.
You could also run through the steps found at Microsoft to see if your issue is resolved using any of those
http://support.microsoft.com/kb/956196
May 11, 2009 | Microsoft Windows Vista Home Premium...
Acer 22" X223w LCD Monitor Logo
198 people viewed this question
Ekse
Lee Hodgson
Lee Hodgson
Steve Sweetleaf
Steve Sweetleaf
