Cars & Trucks Logo
a
alan prestbury Posted on Jun 11, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2007 honda crv steering is slightly sticky when driving normally i.e in a straight line, so when going straight it is sticky/stiff when making minor adjustments to the steering wheel.
Bill Boyd
Level 3:
Top Expert:
  • Honda Master 53,816 Answers
  • Posted on Jun 11, 2016
Bill Boyd
Honda Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11925574
Points
172802
Could be u joints in the steering column , rack and pinion out of adjustment or something binding up under the steering wheel
Honda CRV - Vibration in the steering wheel column when A/C is on.
Check engine mounts. Slight vibration is normal.
1helpful
3answers
On my 2003 Honda CRV Sport, When I lock me steering I get a grinding noise, does anyone what this is? Cheers Alan
if the noise only occurs at full lock then it is the pump clutch slipping which is normal.sounds awful but okay.
My 2003 Honda CRV vibrates every once in a while when holding a steady speed (around 40)and on straight, level road. If I take my foot off the accel, it stops. Almost feels like it is going over speed...
well i would check tires balance and i would check drive line some time the center suport bearing gos out will make car vibrates hope this helps
My 2009 Honda CRV just started vibrating this morning driving to work on the highway. Is there a problem?
Something is causing the vibrating, which is not normal. Need more info-at what speed does it occur, vibrating in steering wheel, or ? What type of climate where you are (driving through something that sticks to the tires can cause vibrating, like road tar). Has anyone else driven the car recently? Could they (or anyone)have hit a large pot hole, curb, minor accident? All these scenarios could cause what you describe. If something was hit as listed, you would need to have the wheel alignment checked, and also suspension components for any damage.
1helpful
Steering problem
Your power steering engine/ pully has gone bad. needs a replacement then.
Take care and do fix it on time before you get the steering rack damaged.
Good luck.
rate this please
1helpful
3answers
Honda crv transmission?
if your trans fluid is full it may be an internal problem in the gearbox even in the converter its hard to diagnose without seeing the car but i can sure try to help if you can add any other noises or symptoms i will see if i can help you pinpoint the problem
Top Honda Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Honda Expert? Answer questions, earn points and help others
