Question about Samsung HT-Z 120 T Theater System
I am looking for sumsung Home Theater Model No. HT-Z120 Mother board
Posted by morwaswi lucas on
5 Related Answers
Anonymous
  • 144 Answers
SOURCE: HOME THEATER SAMSUNG HT-Q100
Your systemn is designed and built to perform 2.1 sound. If you want 5.1 sound you can do 2 things, connect another pair of speakers to the same speakerterminal as your front speakers, however this produces 5.1 stereo sound and not 5.1 surround sound.
You can buy a new system that has the proper connections.
This set will not have the proper decoding software to produce 5.1 surroundsound. sorry.
Posted on Jan 18, 2009
Anonymous
  • 12 Answers
SOURCE: my samsung HT-TZ512 home theater
Do what I do for every piece of electronic equipment I own, especially remote controls. Go to the manufacturer's Website and the go to support and download the user manual in PDF format and save it to your MY Documents file or whereever.
Posted on Mar 08, 2009
Anonymous
SOURCE: Cannot connect my HT-320 home theater to my TV. I
can not get tv sound through speakers---can only get sound from dvd
Posted on Mar 28, 2010
Anonymous
SOURCE: Need Vizio TV code for my Samsung HT-X50 home theater remote!
Mine is 5. Press the TV button and let it go. When it quits glowing press the power button and hold it down. Then press a number (1-86) on the keypad while holding the power button down. If the TV turns off, you are done. Press the power button again and the tv should come on. If it does not work. Release the power button for a second and then repeat with a different number until the tv turns off.
Posted on Jul 24, 2010
My home theatre after every 30 minutes autiomatically
do you mean after 30 minutes the units was shut down, okay still their is a led indicator at the front or any blinking?. if still an indicator but not functioning you must check the power supply unit first of the unit. if it has any bulging parts like capacitor. if none it needs trouble shooting which need a tools like digital tester to isolate where the main cause came from.
May 25, 2015 | Samsung HT-Z120 DVD Home Theatre System
I have a samsung HT-Z120 it show a PROT error
This error means that you are trying to play a region-protected disc that is not in the same region as your player.
It is possible to "hack" the region on your DVD player by following these instructions:
http://www.videohelp.com/dvdhacks/samsung-ht-z120/10244
Please rate my answer.
Thanks,
Chris
Mar 05, 2011 | Samsung HTP-1200 System
I need the remote codes for a Samsung AH59-02291A
The Samsung AH59-02291A remote came with several Samsung Home Theater systems, including the HT-H4530 and the HT-H5500W. The remote is not a universal remote and will not control other devices. You can learn a bit more about the remote by looking at the manual for the home theater system that it came with. The HT-H5500W manual is available on that product support page: https://www.samsung.com/us/support/owners/product/2014-5-1-channel-blu-ray-home-theater-system-ht-h5500w. If you need a universal remote to control the home theater system, look for one manufactured and programmed after 2014 for the 2014 HT-H5500W.
I hope this helps.
Feb 02, 2011 | Samsung Remote Control Remote Control
I purchased a Samsung HT-Z120. When I connect my ipod through the USB I can't get the list of the songs on the TV screen, only 4 alphabetic characters not the titles.
I missed interpret your question,It might be the home theater is not design to to explore the ipod file system, in that case you may use the ipod display to surf the content.Try to use flashdisk, I think it can explore the content. Thanks!... I hope that helps let me in!
Aug 27, 2009 | Audio Players & Recorders
I have a sumsung dvd home cinema system ht.thx25 when I put a dvd in it says disc unknown but when I put a free dvd in from the newspaper it plays.
Is the disc just a regular disc, not HD or blu ray?
Is the disc a region 1 coded disc?
If it is, the unit should play it fine.
Jul 01, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Tengo un ht-xq100 pero esta bloqueado pues en el display aparece un circulo atravesado por una barra no accede a ninguna funcion y alos 15 segundos se apaga automaticamente
I have sumsung HT-XQ100 DVD player it is overheating even it is in cooled room .... I'm afrid to keep it running for long time ...
could you please helpe my ...
Regards,
Jan 30, 2009 | Samsung HT-Q100 System
Remote control or universal remote that works on my durabrand home theater system 2004 model # HT 3915
The easiest thing to do would be to go to an electronics store, look on the back of the remote control package and look for Durabrand.
It should come with a booklet with the setup codes.
Thats all I got for now.
Hope that helped, good lukc, please rate.
May 10, 2008 | Durabrand HT-3915 System
Samsung HT-Z 120 T Theater System Logo
88 people viewed this question
Top Samsung Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
ThaMp3Doctor
ThaMp3Doctor
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
