Heating & Cooling Logo
Laurie Tompkins Posted on Jun 11, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1998 Duo-therm Brisk Air compressor not coming on. Smelled of burnt electrical when first happened. How do I check to see what the problem is?
richie46
Level 3:
Top Expert:
  • Brisk Air Master 12,962 Answers
  • Posted on Jun 11, 2016
richie46
Brisk Air Master
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2941768
Points
58151
Burnt smell is not a good sign. If your compressor is not turning and the clixon does not shut off power you will hear a humming sound and start smelling as unit burns it self up. Chances are your compressor has seized and needs to be replaced.
5 Related Answers
Anonymous
  • 68 Answers
  • Posted on Mar 30, 2009
SOURCE: Dou Therm Brisk Air not running
Turn the ac off go up top the coach and remove the cover. Look for fan blockage, Wasp, mud dauber etc. Caution if it is wasps they will chase you off the end of your coach. Take some spray with you. If there is no blockage the fan motor is toast.
Thanks for using Fixya
Jerry
TheMobilian
Dan Webster
  • 8221 Answers
  • Posted on Jun 10, 2009
SOURCE: compressor not starting
Most likely it is a small round overload found next to the wires going into the compressor. If that one seems ok then the next thing I would check is the capacitor. Might need a start assist.ce5a8bd.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Anonymous
  • 1124 Answers
  • Posted on Jul 09, 2009
SOURCE: i have a duo therm brisk air model 57915-001 leak
Could be the drain path is clogged.. Take the cover off & see if you can get it cleaned..
Bill Long
  • 606 Answers
  • Posted on Aug 13, 2009
SOURCE: Duo Therm kicking on the compressor, getting cold, but no fan!
Shut the power off to the unit, spin the fan blade to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
Testimonial: "Thank You. Since posting this question yesterday, i removed the cover, the shaft moved quite easily. I spun it and then turned on theunit. It works!"
Anonymous
  • 88 Answers
  • Posted on Mar 28, 2010
SOURCE: AC compressor won't start
hi,you might need a new compressor...you will need need to go back were you bought capacitor...buy a hard start capacitor too..this might crank the compressor...hope this helps.if you buy it..call an ill tell you how to wire it...if it dont ,you need new compressor...call michael..doctor airr..appl.repair...843-384-8474...
1988 mallard sprinter travel trailer electric heat, how do I use it
To use the electric heat on your 1988 Mallard Sprinter travel trailer, you will need to follow the instructions for your specific Duo Therm Brisk Air unit. Here are the general steps you can follow to use the electric heat:
  1. Set the thermostat: Set the thermostat to the desired temperature. The thermostat controls the electric heat and determines when it will turn on and off.
  2. Turn on the electric heat: The electric heat on your travel trailer is usually controlled by a switch or a button on the thermostat or on the unit itself. Turn on the electric heat by flipping the switch or pressing the button.
  3. Adjust the temperature: Use the thermostat to adjust the temperature as needed. The electric heat will turn on and off as needed to maintain the desired temperature.
  4. Turn off the electric heat: When you are finished using the electric heat, turn it off by flipping the switch or pressing the button.
If you are having difficulty using the electric heat or are unsure about how to operate your specific Duo Therm Brisk Air unit, you may want to refer to the owner's manual or contact the manufacturer for assistance. They will be able to provide you with specific instructions for your unit and help you troubleshoot any issues you may be experiencing.
Why is my Dometic Brisk Air air conditioner not working?
Sounds like the compressor is seized up and the smell is from the clutch slipping when it tries to engage. If that is the case, you need a new compressor at a minimum.
Duo therm heat pump blowing hot air only
relay module or communication cable from t-stat issue.
Duo-therm brisk air AC unit leaks water into my RV when it rains
take the cover off and make sure the drain line is clear on top off RV.
Nov 15, 2009 • Ovens
1helpful
2answers
My dometic duo therm brisk air RV a/c unit is not cooling the RV
I had the sam problem, took the thermostat cover off and tightend and refastend the wires, so far so god
1helpful
I have a duo therm brisk air model 57915-001 leak
1helpful
Compressor not starting
Top Brisk Air Heating & Cooling Experts
Paul Carew
john h
Are you a Brisk Air Heating and Cooling Expert? Answer questions, earn points and help others
