Question about NetGear N600 Wireless Dual Band Router
How to connect to vonage
Vonage connection to n600 router
Posted by Mary Graves on
John Walker
    Habit-Forming:
    New Friend:
  • 33 Answers
Connect by Ethernet cable one end back of router and other LAN port of the vonage
skype id : [email protected]
Posted on Sep 13, 2016
2 Related Answers
Anonymous
SOURCE: have vonage fax and phone service
I am new in the network field.How can i set up a LAN net work using 5 hosts.What are the devices that I need to set up this net work?This is my email address.You can send it there:[email protected] thanks
Posted on Apr 02, 2008
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: lost passkey to my Netgear N600 Double Band Router wndr 3400
Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.or passphrase etc.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Posted on Apr 05, 2012
Service Hook-ups...
1- in order of what connects to what
1- linksys connects to road runner modem. Should be a network connection on the back of the router that says uplink. This connects to the road runner`s wired port on the back of the unit.
Vonage phone will/should connect through the wireless section an in your personal wifi connection when you get the router wireless setup. Name your wireless something that other people are not using and then tell vonage phone to connect to that network.
Hope this helps
Feb 16, 2014 | Linksys E3000 Wireless Router
My desktop has a local area connection with limited to no connectivity. I had my desktop pc connected to a netgear n900 router and a vonage phone connected to the router's lan1 port. This caused i
Did this connection ever work before? I have a similar setup with Iristel and once in a while it goes down (Hurricane Leslie generated the problem last week).
Check whether the setup works without the Vonage device. This will tell you whether the problem is with your router or the Vonage box. If it works without the Vonage, the problem is in the Vonage box, you may find a good time to call Vonage for support.
I don't know whether the Vonage box (in my Iristel case it's a mediatrix 2 something) has to 'call home' before it lets your router set itself up.
If your router does not work without the Vonage, you have a simpler problem, the router is the issue. You can reconnect the Vonage and if the phones work, this confirms that the router is the problem. At least you can use the phones.
With the router, you need to log in to the admin screens and poke around until you find the problem. It is always a good idea to only change one thing at a time and always remember what changed immediately before the problem was noticed.
Sep 16, 2012 | Gateway Computers & Internet
My Belkin F7D4302 router will not work with my vonage. I have a clearwire modem. If I hook modem into my my vonage first then to my router, my router does not connect to internet but my vonage does, If I...
It should work with the Vonage hooked into the WAN port of the modem, then the router plugged into the router. I had same issue with a Belkin router. Vonage Customer Service will help you at all hours: 1-VONAGE-HELP (1-866-243-4357)
24 hours a day, 7 days a week If you are calling to speak to our technical support team, please make sure you are near the Vonage phone adapter you are calling about and at the location where you intend to use your Vonage service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 20, 2011 | Belkin Computers & Internet
How can router, cable modem & Vonage modem be connected
Connect the Cable Modem - > The Vonage
Then Connect the Vonage -> The Yellow or Green Slot of the router
Connect your computer -> The Grey slot in the router
Run the Setup
Dec 11, 2010 | Belkin (F5D7231-4) Wireless Router
I had vonage took it off have modem connected to router Did hard reset in linksys wireless n can't get a wireless connection But shows connection on laptop
The Vonage unit has to be plugged into the modem then the router is plugged into a port on the Vonage. I had the same issue.
Nov 20, 2010 | Linksys Wireless-N WRT150N Router
I have vonage telephone hooked up to my pc.how do i install my wrt54g router,what wires go where?
Who is your ISP. I think your modem is connected to the Vonage and Vonage is connected to the computer. If that is the connection then you can disconnect the computer from the vonage and connect the router there. From the vonage connect to the internet port of the router. then connect your computer to the router. Check if that works. If you are connecting the router to the modem, then you will need to set up the router as per the modem set up or type of ISP. Click Here for step by step solutions
Nov 17, 2009 | Linksys Wireless-G WRT54GS Router...
I have the RCA DCM425C cable modem and also Vonage phone service. So my modem ethernet connects to my Vonage internet. I would like to go wireless in my house. How would I do this?
You would connect from the output of the Vonage modem to the wireless router and then from the wireless router you can connect Ethernet to your desktop if you have one and then anything else can run off of the wireless.
or
get a wireless router / cable modem combo provided by companies such as netgear then you would connect the Vonage to the router through one of the available Ethernet ports and any other Ethernet connections to the router as well and anything else wireless would work wireless.
Nov 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
New computer (Vista) does not connect to internet. We have vonage VWR-VR D-link router and SBC Yahoo.
If you want this computer to connect wrielessly, go to Control Panel > Network and Sharing Center and click on Connect to Network. Select your router's signal from the list and click on Connect. It might require you to enter a network key. If you don't know your network key, call your ISP.
Apr 18, 2009 | D-Link Vonage-enabled Wireless Router...
Vonage Phone Adapter and Motorola DSL Modem and Linksys NUltra
Your connection should be from DSL modem > internet port of Linksys router > Vonage phone adapter to port 1 of the router.
Nov 01, 2008 | Linksys WRT160N Wireless Router
Vonage does not work with D-Link router
If you plugged a telephone into your D-link router, unplug it - that can not work!
You have to plug your vonage router (WAN port) into the D-Link (LAN port) and connect your phone to one of the LAN ports of the vonage router.
If you do not need the wireless capabilities of the D-Link, you can simply take that one out and only use your vonage router.
If you need more help, I would need more details form you:
Which vonage adapter are you using?
How is your setup (i.e. modem -> D-link -> vonage & computers)
What connections are you using (wire/wireless)?
You can also find help here.
Jun 17, 2008 | D-Link DI-704P Router
NetGear N600 Wireless Dual Band Router Logo
200 people viewed this question
Top NetGear Computers & Internet Experts
Mike
efs_perpends
efs_perpends
Lee Hodgson
Lee Hodgson
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
