Heating & Cooling Logo
A
Amber Cramer Posted on Jun 09, 2016
My DeLonghi PAC A110L portable air conditioner is leaking water. How do I fix this?
Leaking water from 2 different locations
Markus Maritz
Level 1:
New Friend:
  • Contributor 64 Answers
  • Posted on Jun 10, 2016
Markus Maritz
Contributor
Level 1:
New Friend:
Answers
64
Questions
0
Helped
21944
Points
90
Hallo
If an Air Conditioner is on cooling then the Air Conditioner also removes humidity from the air any Split Unit, Window Wall A/C you name it... Any A/C on cooling dehumidify the air in the room.
To decrease the volume of the water:
1) Clean Air filter/s
2) Keep doors and windows close( can open now and again).
I don't know how that portable A/C of your look like but I believe theirs a water pan inside that needs cleaning I think it's full.( best is to service the hole A/C).
Hope this was useful.
Regards
Delonghi PAC a120e ,why is it leaking and also is ther a filter
Don't know if this is the type issue you are having. I had my unit leak all over the place last year and found there was ice buildup on the inside of the unit. You would have to remove the cover completely in order to check this out. Also make sure the drain is clear.
How to remove water tank of delonghi P AC W130 portable air conditioner
OWNERS MANUAL for DELONHI
PAC W130
http://www.delonghi.com/Global/InstructionManuals/GB/GB-5751018800.pdf
1helpful
How to change or clean the filter and where to download a manual
DeLonghi has the manuals for their portable air conditioners here: http://delonghiusa.com/support/product_manuals/5#table-jump . The direct link to the PAC C120 manual is http://delonghiusa.com/support/sites/default/files/product_manuals/m-PAC+C120.pdf .
Before cleaning, turn off the air conditioner. To clean the filter, pull it straight up from behind the top of the air intake (on the back of the PAC C120). Vacuum off the filter. If it is very dirty, immerse it in warm water and rinse several times. (The water should not above 40 degrees Celsius (104 degrees F)) several times. Then allow the filter to air dry. Slide the filter back into the air conditioner and turn the unit back on.
I hope this helps.
My PAC C110 air conditioner leaks a lot of water why?
Water leaking due to:
1. Non insulation of copper pipe lines.(Insulate with insulation material) 2. Dust blocked in drain pan. (Clean it) 3. Cooling coil and air filter blocked. (Clean it)4. Airlock in your drain line. (**** air from your drain line)
6helpful
I have a Delonghi PAC A110L that has stopped working. When you plug it in it starts up but then powers down giving an error message that looks like FE but with the top line missing from the E
The unit is full of water at this point. If it is real humid it can not get rid of in fast enough via the air duct. Look for plug in back low. Watch out, have unit outside or a low pan to catch water when you pull the plug.
1helpful
I have a DeLonghi air conditioner model # PAC A110L that is leaking water from the bottom of it. I lost the manual (ofcourse) and I need to know who to fix this issue. THanks! :)
its condensation,which is normal,try tilting the unit back a little so that the water can get to the drain hole in the back of unit.
2helpful
DeLonghi portable airconditioner leaking water
nbenz ,
Welcome to fixya.
I'm Huuum and happy to assist you,
Portable units are supposed to spray the water on to the hot compressor an evaporate the water!
If it is only 3 weeks old ,you have a 1 year warranty. call service and let them fix it for !
Please remember to leave a rating before you go!
Thank you
Top DeLonghi Heating & Cooling Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
