Food processors have mechanical interlocks between the bowl and the base and between the base and the top. Be completely sure everything is lined up and twist-locked into place. You may see a mechanical linkage down the side of the bowl, which should be perfectly lined up with a hole in the base and another linkage in the lid.
Try this procedure:--
It usually goes something like this, with minor variations depending on model number:1.Remove the work bowl completely from the base 2.Plug the food processor in and turn it on 3.Use a pen to depress the dark grey/black button on the base – if it spins, proceed 4.Put the work bowl on the base with the handle facing the front of the food processor – slide the work bowl until it locks - the white tabs show in the openings on the bottom of either side of the work bowl 5.Place the lid on the work bowl with the tab slightly left of the center of the work bowl handle – slide the lid counterclockwise until it won’t slide any more 6.Place the pusher sleeve in the feeder tube of the lid with the lock facing the front of the food processor (may vary depending on model) 7.Slide the lock to the right into the locked position The food processor should now work.This will help.Good luck.
Check out this options
Remove the work bowl completely. Turn the machine on and use a pen to depress the dark grey or black button on the base of the Food processor. If the motor doesn't spin, it needs repair. If there is spinning:Make sure the handle of the bowl is facing the front of the food processor. Place the lid tab just to the left of the handle and slide it toward the handle until it won't turn anymore. Remove the pusher sleeve from the lid and reinsert it with the lock facing the front of the food processor. Slide the lock into the locked position. If it still doesn't work, replace the third piece on the work bowl - the one piece that you haven't replaced. It will then work.This will help. good luck.
Read the handbook and make certain you are assembling the bowl, lid and pusher correctly, they can all play a part in activating the safety mechanisms that put the appliance in the mode that will allow it to be started.
It is most likely the way the bowl and lid are set.
Facing the machine: the bowl locks in, with the handle to your right directly above the switches. The lid has a double tab...see underside of the top of the lid. Place the lid on tightly with both tabs locked into bowls handle. It really clicks in.
Remove the work bowl completely. Turn the machine on and use a pen to depress the dark grey or black button on the base of the food processor. If the motor doesn't spin, it needs repair. If there is spinning:
Make sure the handle of the bowl is facing the front of the food processor. Place the lid tab just to the left of the handle and slide it toward the handle until it won't turn anymore. Remove the pusher sleeve from the lid and reinsert it with the lock facing the front of the food processor. Slide the lock into the locked psoition. If it still doesn't work, replace the third piece on the work bowl - the one piece that you haven't replaced. It will then work.
It usually goes something like this, with minor variations depending on model number: 1.Remove the work bowl completely from the base 2.Plug the food processor in and turn it on 3.Use a pen to depress the dark grey/black button on the base – if it spins, proceed 4.Put the work bowl on the base with the handle facing the front of the food processor – slide the work bowl until it locks - the white tabs show in the openings on the bottom of either side of the workbowl 5.Place the lid on the workbowl with the tab slightly left of the center of the workbowl handle – slide the lid counterclockwise until it won’t slide any more 6.Place the pusher sleeve in the feeder tube of the lid with the lock facing the front of the food processor (may vary depending on model) 7.Slide the lock to the right into the locked position
-Tha Mp3 Doctor
-Tha Mp3 Doctor
