Hallo
Frost free means there is an evaporater coil behind the backplate of the inside of your fridge.
How it works is a fan is for example installed in the lower back of your fridge and the evaporater above the fan covered by a plastic cover/steel plate and now the fan is pulling the warm air from the top over the evaporater ( the evaporater is then pulling the warm air into the evaporater without increasing the temperature of the evaporater) and dehumidify at the same time and blowing the cold air out a the bottom of the backplate while the warm air moving to the top where it could repeatedly repeat this action.
Tell me what is the condition of your freezers door seal? It can only be caused by humidity getting in so it mean the door is not sealing 100%.
Regards
SOURCE: freezer compartment
You need to defrost the whole fridge and at the back in the freezer compartment you will c a small drainage hole.. look for it.. The get a piece of say hanger wire and clean this pour some hot water from a kettle down it and then start your fridge up again. that should sort your problem out ... if not then its either a sensor or a board fault...
SOURCE: Ice build-up on the inside top of of freezer door
This is a problem that the factory has released a bulletin on.They have released new hinges, and insulation for inside the door. So far I've only seen the bulletin for Kenmore upright freezers made by Frigidaire. Since it is a Kenmore the bulletin is a Sears Service Flash but the units are identical. For sears its SF46-517. They may extend the service to Frigidaire units but you'll have to contact Frigidaire about that.
SOURCE: Frost gathering in freezer, icemaker dispenser freezes over
well check to see if door seal is split if it is get new one!! need to see photo of the frozon over dispenser- found before that when ice not bein used alot the odd time you will have to take out the ice in the bucket crack it up and put back in try this???
SOURCE: hotpoint frost free ff200e flashing lights and
Make sure fridge OFF freezer OFF ... then turn mains on. ONLY turn freezer to max, after 30mins put fridge to 1care ... this should overcome the problem of the flashing lights. When both nice and cool turn settings down. it worked for me
SOURCE: SERVIS MO262S FROST FREE FRIDGE/FREEZER, FRIDGE NOT WORKING
servis frostfree fridge freezer not working after 2weeks holiday returned it had completely defrosted fridge & freezer power supply still connected. warning light on. done all the trouble shooting in the srvice manual still want go cold or freeze. light on in the fridge, no water in the rear tray & cleaned the overflow pipe??. Model No M0330-ALU 5yrs old. think it has 2 seperate thermostats, surely they wont both have gone at the same time???????
