Konica Minolta bizhub 750 Logo
Shoaib Bhatti Posted on Jun 09, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Heloo iam shoaib iam tec bizub 750 my proublem c-b116 eror what is
Errror code is c-b116
Ravi
Level 3:
  • Konica Minolta Master 1,682 Answers
  • Posted on Jun 09, 2016
Ravi
Level 3:
Answers
1682
Questions
Helped
580110
Points
8910
My machine bizub 600i show on screen c3503 how to remove this by which i cando
Power off the machine, using the main power switch located inside the machine. Then ensure the sub power switch is on that's the one on the control panel. Now depress the Utility/Counter button and turn on main power must keep the button depressed. once you see trouble reset touch it get a OK. Power off then wait ten seconds and power back on. If the code comes back do not reset again the machine can catch on fire and that will ruin a perfectly good day. get a technician to look at it The Fuser is not something to mess around with.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Wii cyberbike how fix control pad
well i have the same proublem trying to get a replacement part from bigben interactive Iam still waiting to see if they can get the part or the complete handle bar
Jan 05, 2014 • Cycling
Iam using nokia 5130.iam having the habit using always security code.for past few months my mother used the mobile.so i switch of the security.now again i want to use the security code.i know the old code...
just reset your mobile. switch off your mobile and press all the following keys all together *,3, call button and power button. when the screen starts just release all the keys and you are done
TEC 472 Error message- SG: 139, 0010, 064
This is syntax error, the coorect is SG;0139,0010,064....
1helpful
Sound drivers problems
WWW.DRIVERSHQ.COM
OR
GO ON LINE AND TYPE THE FOLLOWING INFORMATION INTO THE ADDRESS BAR:
COMPAQ LABTOP ERROR CODE 88780078
ENTER
Error code C-B116, what does it mean?
Code
B116
Description
Communication error with the fax board
An undefined communication error occurs between the controller and the fax board.
Remedy
1 Check the connector CN106 on MFPB for proper connection and correct as necessary.
2 Change FAXB.
3 Change MFPB.
That error means a problem with the FAX Board. Now, checking connections or re-seating connections of fax board to main board are advised first, then replacing fax board if that fails.
My computer only shows a blue screen with writting all over it
heloo hai iam eshwar
please power off your system and open the cpu and remove Ram and clean it and completly clean dust on your system
now insert ram another slote .power on your system
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
