If after adjusting your thermostat to desired temp and is still cooling. The thermostat is bad or your relay is bad
If you disconnect the thermostat and the compressor stops it most likely a bad thermostat
If you disconnect the relay from
The thermostat and it stay running it is the relay. It is sticking
If possible store you wine somewhere else and shut the unit down and unplug for 10 to 20 minutes this may cause some melt of condensation some water may be on the floor if is to cold
This may also reset the system.
First make sure it is not plugged into an extension cord. Low voltage could cause this type of problem. If you have it plugged directly in ,It is probably the compressor or overload relay on the compressor. You can bypass the thermostat to see if it is the problem, by first unplugging the device, then removing the wires from the thermostat, and jumping them together. Then plug it in If it still acts the same way the problem is in the compressor or overload relay mounted on the compressor. Sometimes the relay can be purchased and replaced or a hard start might work solve your problem.
Possible bad thermostat. Bypass the thermostat wire to run the compressor. If the compressor start, replace the thermostat.
On the other hand if the compressor is running, and there is no cooling; there is a leak and all the refrigerant probably escaped. If it is the case, you need to call serviceman and have him evaluate the wine cooler for possible repairs.
P.S. The serviceman may charge a fee for evaluating or estimating the cost of repairs.
LL is an error code which means that it is too cold. Surprised that it didn't freeze something. Problem is likely the thermostat ($15 -
RF-7350-55) or motor control board ($50 - RF-0668-04).
You may find that the thermostat is not working. Try to turn the thermostat to the warmest setting, the compressor should switch off within two hours, if not change the thermostat.
First check the grating over the fan in the back. If it is covered
with dust, there won't be enough air flow and the unit won't cool.
Clean the dust off and see if it cools back down. It may take a long
time to cool down if it is full of wine, so I recommend taking the wine
out to test if it works.
GO TO THE LOWER BACK OF COOLER PUT YOUR HAND ON THE COMPRESSORTO SEE IF IT IS RUNNING ,BR CAREFULL IT MIGHT BE HOT,LET ME KNOW AND WE'LL GO FROM THER,MIIKE
