Re: What's your question?HiTi P110S " Unsupported Ribbon...
May be a compatible rather than origial part, this is a common message on inkjet printers too, happens because an on board chip cannot read a chip on the cassette / tank being used
HiTihttps://www.hiti.com > files > Product > P310W...
It can cause a fire, electric shock or printer problem. Do not place the printer with dust, sand and high humidity such as bathing place, bathroom, hot spring, ...
14 pages
HiTihttps://www.hiti.com > P310WUserManual_all
case of irrecoverable problem, please contact HiTi dealers or service center. Page 5. English. HiTi P310W user manual. Chapter 1. Important Safety Instruction.
157 pages
If you're experiencing a "Ribbon Missing" error on your HiTi S510 photo printer, here are some steps you can take to troubleshoot and resolve the issue:
Check Ribbon Installation: Ensure that the ribbon is properly installed in the printer. Open the printer's cover and verify that the ribbon is securely inserted into the printer's ribbon cartridge or holder. Make sure it is correctly aligned and positioned according to the printer's instructions.
Clean Ribbon Contacts: Over time, dust or debris can accumulate on the ribbon contacts, preventing proper communication between the printer and the ribbon. Use a clean, lint-free cloth or cotton swab lightly dampened with isopropyl alcohol to gently clean the contacts on both the ribbon cartridge and the printer. Be careful not to apply excessive pressure or damage the contacts.
Reset Printer: Try resetting the printer to clear any temporary errors. Turn off the printer and unplug it from the power source. Wait for a few minutes, then plug it back in and turn it on again. This can help reset the printer's internal settings and potentially resolve the "Ribbon Missing" error.
Replace Ribbon Cartridge: If you have access to a spare ribbon cartridge, try replacing the current one to see if the error persists. Sometimes, the ribbon itself may be faulty or incompatible with the printer, causing the error message. Make sure you are using a genuine HiTi ribbon cartridge that is specifically designed for your printer model.
Update Printer Firmware: Check if there are any available firmware updates for your HiTi S510 printer. Visit HiTi's official website or contact their customer support for information on firmware updates. Updating the firmware may address known issues or improve the printer's functionality, including proper ribbon detection.
Contact HiTi Support: If the issue persists after attempting the above steps, it's recommended to contact HiTi customer support directly. They have access to specific troubleshooting steps and can provide further guidance based on their knowledge of the HiTi S510 printer. They may be able to diagnose the issue remotely or recommend further solutions.
When contacting customer support, provide them with detailed information about the issue, including any error messages or specific symptoms you are experiencing. This will help them provide more accurate assistance and advice tailored to your situation.
Note: Always follow safety precautions and consult the user manual or contact the manufacturer's support for specific instructions and guidelines related to your HiTi S510 printer.
rror code 0201 on the HiTi C290 printer indicates a problem with the ribbon. Here are some steps to troubleshoot the issue:
Open the printer cover and remove the ribbon cassette.
Check the ribbon for any damage or wrinkles. If there is any damage, replace the ribbon with a new one.
Ensure that the ribbon is installed correctly in the cassette and that the cassette is inserted properly into the printer.
Check the ribbon sensor to ensure it is clean and free from any dirt or debris. You can clean the sensor using a soft cloth or cotton swab.
If the problem persists, try resetting the printer by turning it off, unplugging it from the power source for 5-10 minutes, and then plugging it back in and turning it on again.
If none of these steps work, contact HiTi customer support for further assistance.
It works by using a dye ribbon. My guess is that there is something in the blue ribbon feed stuck to the roller, or the paper feed. The machine is discontinued, but you could reach out to the maker.
Designed as a mini photo station with less than 20kg, HiTi P510K is integrated with 10.2-inch TFT LCD touch screen tilt-able, industrial computer system, ...
Apple has a habit of dropping older printers with their newer operating systems. Check the printers website for a solution and maybe try the driver from a newer model.
