Washing Machines Logo
Question about Electrolux Washing Machines
Frigid aire Electrolux washer/dryer model GLET1142CS0 my washer won't start unless my dryer is running also.
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: Frigidaire GLET1142CS0 washer wont spin
I Changed the TUB belt and now it spins.
Posted on Jun 12, 2008
Anonymous
SOURCE: Frigidaire Washer Dryer Combo: Dryer Only works on washer spin
Are you connected to a 30 amp breaker w/ 30 amp wire?
Posted on Feb 23, 2009
Anonymous
  • 6784 Answers
SOURCE: When washer fills it does not stop unless done manually
HI, i recommend testing the timer/control device for faults. make sure it is spinning and not shorted. if the timer/control device is in good condition, this will confirm a serious fault in the water valve assembly(inlet). replace this device in this case.
Posted on May 22, 2009
Anonymous
  • 6277 Answers
SOURCE: Bought "Electrolux eco turbo lava
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Posted on Feb 27, 2011
Anonymous
  • 92 Answers
SOURCE: i have a frigidaire glet1142cs0
UNPLUG THE MACHINE. Take the back off the dryer, usually 4 to 6 screws. On the backside of the panel you just took off should be a schematic showing where the thermo fuses are.
Take an ohm meter and check across the prongs sticking up, you may have to unplug them to get good contact. They should show 1, open, if they show 0, short. they need replaced. There are online parts companies that can help you get the right part.
It is unlikely that the element is bad, but if the thermo fuses show open, then you should be able to see the element, and replace it.
Posted on Mar 27, 2011
1helpful
Electrolux 7kg sensor dryer stopped starting to spin unless you started it by hand now nothing works at all.
what do you mean start it by hand,do you mean if you spin the drum by hand helping it to spin it starts if so you have a bad motor.also next time send the full model number off of the dryer.
No power to dryer. Checked. And rechecked breaker
All dryers have one or 2 safety devices mostly near the vent pipe. They are rated for 350f and are tied into the motor circuit so if a dryer overheats (unless it is gas) it won't run. The dryer posted looks like an electrolux and the fuse on it mounts in the upper right hand corner. My repair page on electrolux at the base of my blog https://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes/dryer-will-not-work
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 08, 2014 • Dryers
3answers
I own a 1Q-Touch Front-Load Electrolux washing machine. The door won't open. What can I do?
Hello Elizabeth P Cochran - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If the door does not open, then it sounds like the washer is possibly experiencing a communication problem with the control board, wiring failure or faulty door lock. Contact a professional to move forward accurately to properly diagnose/repair unit.
Electrolux Lavamat Turbo 16830 Washer/Dryer but dryer not working
Has the little belt on the dryer turbo come off? or is the turbo seized - it should turn freely by hand. You may need to replace the turbo fan if the belt keeps coming off - the pulleys can get out of alignment, ie not running parallel to each other - they tend to be cheapo plastic construction these days. Could also be dryer elements or thermostat problems, or blockage with lint causing reduced air flow and overheating - but check belt first.
1helpful
Open Questions:
Top Electrolux Washing Machines Experts
nu267
tina gallow
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
