Question about Furniture
I have a igloo 48 bottle wine cooler, and it will show error code "LC" and then you can not adjust the digital temperature or turn the light on. It fridge still feels code? Any ideas would be great!
Posted by Greg Vandenberg on
Callum Dooley
    New Friend:
Hi Jen, I know this is a little out of date.
But for people who are still looking for a wine cooler with a capacity of 48 bottles, here is a good example: https://www.elitefridges.co.uk/products/dunavox-48-bottle-freestanding-wine-cabinet-dx-48-130kf
We have a Dunavox fridge ourselves, no cmplaints so far
Posted on Jan 15, 2019
David Parker
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 12 Answers
Could be the temperature sensor. There should be a support number in the manual you can call. Hope you can get it fixed. if not check out my blog for help choosing your next cooler. The Best Wine Coolers The Complete Guide Vino Coolers
Posted on Jun 15, 2016
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: wine fridge light does not turn off
You may know this already, but for what its worth. There is a small switch on the bottom vent grill for on/off of light. Check there first.....
Posted on Feb 01, 2009
Rich Wright
  • 286 Answers
SOURCE: uline wine cooler 2075wc doesnt work, light goes on ????
If nothing runs but the light is on then change the thermostat. #2767-1 and you can find a part from a distributor. To find one visit www.u-line.com and under customer service you will see parts locator
Posted on Jun 15, 2009
Anonymous
  • 14 Answers
SOURCE: Vinotemp VT-16TEDS has light on but doesn't cool
You may need to change the cooling system on the unit if the unit is free of dust and still does not cool.
Posted on Sep 21, 2009
Anonymous
  • 1478 Answers
SOURCE: Both zones of the wine
Check the thermostat for temperature setting. Also check the condenser coils and clean them if found clogged with dust. Unplug the wine cooler and wait for a couple of hours before plugging it again. If you can hear it running or whining, perhaps the compressor is being overheated. Test various components such as temperature control knob, evaporator fan, defrost timer, compressor relay, overload protector and the compressor motor.
Take care.
Posted on Oct 22, 2010
Azrael SRL
  • 11800 Answers
SOURCE: Temperature display has steady blinking
This unit uses a thermoelectric element to generate the cooling, not a compressor. Because of that its temperature setting is extremely sensitive and the fans must be fully operational.
The blinking of the light signals that the temperature setting cannot be maintained because a component failure has occurred. The most likely part to have failed is one of the fans so you will have to inspect them both and replace if necessary. If they are ok then you will have to check the thermistor and the control board, in which everything else plugs in.
A basic knowledge of electronics is required for that, if you don't have it then ask someone you know to help you. Calling Vinotemp is out of the question , the bill would be higher than the price of a new cooler.
Posted on Jun 27, 2011
Temperature Light Bling
http://www.danby.com/cms/documents/pdfs/en/DWC114BLSDD_EFOM_%28DM%29_FINAL.pdf
set the temp higher,or check front exhaust vent,"a low temp means it is too cold,adjust the thermostat to a warmer temp"
Mar 14, 2015 | Danby DWC114BLSDD 38 Bottle Dual Zone Wine...
E1 error code LFWC38F6LS
Good Morning Chris,
I see that you are receiving an E1 error code on your wine cooler, model# LFWC38F6LS, even though your wine cooler is still working. This could possibly be a false error code, caused by a miscommunication between the different control boards inside your appliance. I suggest resetting it by either unplugging it or cutting the power at the circuit breaker for 2-3 minutes. If when you bring power back to your wine cooler, you are still receiving the E1 error code, I suggest contacting either the manufacturer or your local authorized technician. Hope this is helpful.
-Best Regards-
WP
Mar 18, 2014 | Frigidaire 38-Bottle Two-Temperature Zone...
We just received our Danby 35 bottle wine fridge with digital temperature display, and cannot turn off the light.
I found the users manual for your Danby! You have erroneously called it a 35 bottle unit, when in fact it is a 50 bottle unit. Click HERE for you manual. In the manual, it says you can use the light manually or automatically. There appears to be a switch on the bottom of the unit. I suggest the manufacturers manual for it holds a great deal of information that can be of assistance in the future, as this is a discontinued model
Good Luck, and I hope this is the answer you are seeking. Please rate and comment, Thank You Joe
Sep 07, 2011 | Danby Silhouette DWC512BL Wine Cooler
My thermostat is reading 48 and I can't get it cool enough in my wine cellar to turn off the unit so that I can adjust the temperature up to 55. Is there a place that I can put some ice on to lower the...
IF THE CELLAR TEMPERATURE IS AS YOU SAY 48 DEGREES AND IF YOU ARE TURNING THE SCREW ADJUSTMENT ALL THE WAY TO THE WARMER SETTING COUNTER CLOCK WISE AND THE UNIT DOESNT SHUT OFF YOU HAVE A BAD THERMOSTAT AND NEED TO REPLACE IT
Aug 04, 2011 | Breezaire WK2200 (265 cu. ft.) Wine Cooler
Digital temperature display is missing part of the
You are going to have to replace the display. Easy fix even if you are not very familiar with this system
Jan 02, 2010 | Oster 12-Bottle Wine Cellar - Black
Chamber wc902 wine cooler which wont set temp
I have the same issue especially when there is a power outage. To reset it, press the preset until "1" appears, then adjust the temperature as low as it will go by repeatedly pressing the temperature "-" button. Usually works.
Oct 08, 2009 | Tower Chambrer WC601B 7 Bottle (6+1)...
Uline wine cooler 2075wc doesnt work, light goes on ????
Nov 01, 2008 | U-Line 75WC Wine Cooler
Furniture Logo
933 people viewed this question
Top Furniture Experts
John Tripp
John Tripp
Tom Chichester
Are you a Furniture Expert? Answer questions, earn points and help others
