Question about Panasonic Viera TH-50PX80U Plasma TV
On my screen the right hand side has a strip of black so that it looks like it has the wrong format, but cable company has checked it out and says it is a problem with the tv itself.
Posted by Jan Taylor on
Electro Med Services
  • Panasonic Master
  • 6,694 Answers
The TCON Board or the LCD panel is faulty. Can confirm by replacing the TCON board.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Posted on Jun 07, 2016
I have an Element flat screen tv that has two 3-4" black strips vertical on both sides of the screen. It was not like that before I watched a movie then I switched the tv back to data lite mode and th
Look for the aspect button the remote for the set or on the box if one is used-----Set is in the 4x3 format and that is what that format looks like.
Dec 14, 2012 | Televison & Video
The right shift key does not work as well as a few of the upper left control keys...everything else seems to be working just fine.
Hi there , this might be the ribbon cable connecting the keyboard to the laptop , lay the screen flat , look at the left hand side of the lap top , there is a strip you can lift up , where the power switch is. lift the strip up , you will now see the two screws holding the keyboard down, unscrew them , slide the keyboard up slowly and lift , gentaly you will now see the small riben cable, lift the small black catch , then reseat the cable , push the catch back, and reseat the keyboard. now retry the keyboard ...
Nov 13, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
I have a black screen. Cable company says I have
This is a common problem with Cable companies when they update their firmware. This makes the two incompatible. You can try going onto www.samsung.com and look for firmware updates for your model. Follow the instructions provided. If this does not work then you have a bad cable box. Cables companies are notorious for blaming the tv. Don't let them fool you. Stand your ground and insist on them correcting the problem.
Apr 15, 2010 | Samsung LN-T3253H 32 in. LCD Television
How can i locate and change my cmos battery for laptop fujitsu siemens v2010 pro
The above post sounds simple it is Not, the COMS battery in a Fujitsu V2010 is located just to the left side of the left hand mouse button,( just about where it says AMILO Pro) (under the top cover)
(All power off battery out)
To get at it you remove all the base cover screws including the four on the back edge.
Turn the laptop over and remove the power buttons plastic strip by levering upwards between the gaps that are to the left of the Num Lock key and the right of the Esc key, (use a very thin screwdriver) or slide a screwdriver between the Num lock key and cover leaver upwards, then do the same at the Esc key side, the four retaining lugs are left and right of the cover.
The screen should be laid flat as you do this or you will rip off the keys.
Unscrew the wrap over bracket (right of screen) that holds down a thin black cable.
Pull upwards (carefully) the three connectors in the two recesses below it. (Two in left recess one in right recess)
The cables in the right recess are held down with a strip of black tape remove it and remove the cable from the retaining lugs.
Remove the keyboard screw and push slightly towards the screen to get at the retaining strap and remove the strap by levering the lugs upwards on both sides, put the keyboard to one side.
The wireless card cable is slotted in a channel lift it out. Then unclip and lift out the card still attached to the cable.
Remove the left and right screen screws and carefully lift upwards and remove the screen with the wireless card still attached, put the screen to one side,
Remove the four RAM cover screws and lift off the cover put to one side.
There are 3 tiny screws at the back that are just under the screen location remove them, the last screw is just under the key board in a deep recess remove it.
Finally lift the top cover up slightly and push slightly towards the screens location as the COMS battery is attached to the mother board at front left. (Unplug it)
Work very carefully making sure you do not miss any screws, if it will not come off you have missed something. CHECK.
The cover should come off without any resistance.
The screws are different sizes apart from the base cover screws,( TIP) tape a wide strip of cello tape sticky side up on your work bench and group the screws on it marking with felt tip where the were located.
The wires on the battery are RED and BLACK
Leaver out the battery it’s held firmly by a sticky pad and change it (the wires come attached to the new battery. (Battery VARTA CR2032 3v 0405)
I am writing this from memory but I don’t think I have missed anything, remember if it will not move do not force it LOOK. (Something’s can be done not exactly in the order I have tried to explain it)
Replacement is the reverse of removal.
One site I was looking at wanted £45 for changing a keyboard, that’s a real rip off.
Hope this helps if in doubt take it to a shop.
Best of luck. teastheword find me on E Bay.
Jan 09, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
Black strip left hand side of moniter screen not being filled
The monitor should have some kind of menu, accessible through the buttons on the side or bottom. In there you can move te display area to the left. If you then get a bar to the right, you should change the monitor resolution to the highest it can display.
If the bar on the left persists, you should check wether the PC-monitor cable is properly insterted. If so, try another cable. If that doesn't help either, try another monitor.
I hope this helps,
Yannick.
Oct 05, 2009 | LG L192WS LCD Monitor
Black strip down the right hand side on my viera plasma
Hello
black strip down the right side its about 2 inches wide there are also red and green flashing lights that is defective shorted capacitor at power inverter board section that was 300uf 200volts.
Angel
Thanks...
Aug 02, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Vertical strip paler than rest of the screen
Check connectore for that area, may be loose, release the cable before pulling, and reinstall it. See if that works.
Dec 11, 2008 | Televison & Video
Only displays white screen
Hi, Its a strip problem,when u change your mobile strip then screen willbe ok! By: M.Qasim Butt
Apr 13, 2007 | Motorola Mobility RAZR V3
Panasonic Viera TH-50PX80U Plasma TV Logo
47 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
