Question about Sharp Office Equipment & Supplies
My Sharp AR-M256 is displaying Code H2-00, how can i remove this?
Call for service error code H2-00 is displaying on my screen
Posted by Aderibigbe Seyi on
Electro Med Services
  • Sharp Master
  • 6,694 Answers
If you wish to get some details; check the site linked here. Pull up older posts......
http://electro-medical.blogspot.com/
Posted on Jun 07, 2016
MY SHARP AR-M207 DISPLAY ERROR CODE L4-00 KINDLY GIVE ME A SOLUTION
Hi Alafin,
An error code of L4 suggests a motor error. It could be something as simple as a loose cable but it could be a bad motor. I would suggest you call on a local dealer to repair this as you will probably need new parts.
Jun 14, 2016 | Sharp Used AR-M207 Copier Printer Scanner
I have a sharp AR M256 we were getting an error toner replenishment in progress. CAll FOR SERVICE. CODE H4-21
sir
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"#" key "*" key "C" key "*" key
Main code 14 Start key Sub code 0 Start key
OR
"#" key "INTERRUPT" key "C" key "INTERRUPT"
2. Canceling the simulation mode
When the clear all key is pressed, the simulation mode is cancelled.
When the interruption key is pressed, the process is interrupted and the
screen returns to the sub code entering display.
* After canceling the simulation mode, be sure to turn OFF/ON the
power and check the operation.
Note: If the machine is terminated by a jam error or paper empty during copying in the adjustment by the simulation, recopying is required.
DO NOT CONTINUE RESET AS THIS CAN CAUSE A FIRE AND RUIN A PERFECTLY GOOD DAY. REPLACE THE FUSER UNIT
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 09, 2015 | Sharp Office Equipment & Supplies
How to fix Sharp Copier AR-5731 Error code
good day, my Sharp AR 5731 showing the message Call for Service . Code : H4-00 can you help me to fixed my problem. thanks and God Bless
Mar 11, 2013 | Sharp AR-BC260 Color Copier
Sharp ar-m256 driver
Manufacturer: SHARP Hardware: SHARP AR-M256 Software name: SPLC Printer Driver Version: 0702a File Size: 5.82Mb (6103906 bytes) Released: 14 Mar 2007 Uploaded: 10 Apr 2010 Views: 319 Downloads: 58 System: Windows NT Description: SPLC Printer Driver for SHARP AR-M256
Oct 03, 2010 | Office Equipment & Supplies
Hi have a ar-m256 displaying error code u2-40 how do i fix please?
enter code (# interrupt C interrupt) then give 16 then press copy.
Jun 17, 2010 | Sharp AR-5316 Advanced Digital Imager...
H5 flashing on the display, anyone tell me what the error is please? It's a Sharp AR-161 copier
H5 doesn't show up on the service code manual. However, all error codes beginning with 'H' are related to the fuser, this is the heating portion of the machine. Be careful if it still prints despite the error code, you may damage the unit. It should be looked at by a service rep.
Jan 12, 2010 | Sharp AR-161 Laser Printer
Sharp AR-150N displaying F2 Error code.
Hello sir; I can't find this error code in my manu please check your code again.
Aug 12, 2009 | Sharp Office Equipment & Supplies
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
274 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
