GET HOT CLEAN FILTER STILL TAKES TW CYCLES TO DRY
SOURCE: Dryer heats but doesn't dry
Sounds like it is only heating on "low". The problem is most likely a thermal limit switch/thermostat which is bad.
SOURCE: Dryer takes hours to dry a load. I must run it
My only thought is to look at the back of the drier. Check the hose coming out the back to the out side vent, and then run the drier with out the hose for a few moments. See if you have air moving then, if you have no air moving with out the hose attached. Your driers fan blades are ether clogged with lint or they have broken off some how.
SOURCE: New gas dryer does not
Verify good AIR flow, all the way to the outside of the building. Pull the hose off of the back of the dryer, turn it on, and form an opinion of air volume. Hook back up, turn on again, go outside and verify similar air volume.
SOURCE: My stackable washer/dryer is taking
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
SOURCE: electrolux dryer reading clean filter
Hi
You have excess lint built up in your machine.
Pull out lint filter and with the aid of a brush gently clean inside of the cavity where your lint filter fits into. There is a little sensor in there which once it gets clogged it will register that message.
Ash
