Question about Bernina Artista 180
The presser foot doesn't sit all the way down in order to sew correctly. Can I adjust it myself? How?
The presser foot does not go all the way down to sit on the feed dogs. It won't sew this way.
Posted by MJ Lonero on
R.A. Ellis
  • Bernina Master
  • 12,731 Answers
Has that particular presser foot worked in the past? Do the other presser feet work?
If it hasn't been used before, check that it is the correct foot for the machine. Is it perhaps a darning foot or free motion foot? If so, those particular feet are made to Not rest on the feed dogs so that the fabric can be manually moved without the use of the feed dogs.
If none of the presser feet work with the machine, then the needlebar has probably shifted. It may be best to take it for service as it may require specific tools and gauges to adjust it properly.
Presser feet for every purpose
Manual:
https://www.bernina.com/en-US/Support-US/Machines/BERNINA-artista/BERNINA-artista-180
Posted on Jun 05, 2016
Error message foot too high. To correct this, it is necessary to restart the machine. Unless it is impossible to continue sewing.What is the problem?
Try taking your presser foot off and lower the presser foot lever. Does the error code go away? The machine won't sew without the presser foot to hold the fabric down, but without threading the needle, will the machine run without the presser foot? Now try the standard presser foot (usually J ) and if you get the error code then the sensor at the top of the presser foot assembly is out of adjustment. Without knowing more about your machine this is all I can suggest.
Good luck,
Bob
May 30, 2017 | Sewing Machines
Model 60-7000M. All works except foot rest. It will not close. Help!
Not sure what you mean by foot "rest." If it is presser foot, then you may not have the correct presser foot for your machine (basically, there are 3 types--low shank, high shank, & slant shank). Usually, there is also a pressure adjustment for the presser foot that increases the amount of pressure applied to the fabric and feed dogs. Consult your owner manual. Pressure adjustment is usually either a dial, a plunger type on the top left of the machine (pushing down increases the pressure--push down on the outer ring to release it), or a screw at the very top of the presser foot bar (sometimes under the top lid).
Dec 29, 2016 | Sewing Machines
Can you adjust the needle assembly up higher for thicker garments like thicker coats etc. on Kenmore sewing mach. model 158-13360
On some machines, you can lighten the amount of pressure the presser foot applies to the fabric. (Some machines do not have this capability.) But, you don't want to adjust the height of the presser foot.
If the fabric is pushing in front of the presser foot as you are sewing, you might want to try using a walking foot, a teflon foot, or a roller foot.
Kenmore 158 13360 Sewing Machine If this is like your machine, the pressure adjustment is the upright pin at the top left side of the machine. The inner pin pushes down (in various degrees), the further it is pushed down, the more pressure the presser foot applies. To release the inner pin, press down on the outer ring of the pin. It will snap back up where you can again push the inner pin down in degrees. BTW, it is a good idea to always release this pressure pin when you store the machine. If not, what happens is, over time the spring that applies the pressure becomes compressed and no longer applies pressure like it should.
http://makeitsew.biz/presser-foot-pressure
Sewing Machine Pressure Settings for Machine Quilting
Dec 20, 2016 | Kenmore Sewing Machines
The presser foot won't go down.
Yes indeed, it is possible--sounds to me like a screw worked itself loose. However, I would purchase the service manual for your machine. As a bonus, it tells you how to make all kinds of useful adjustments.
Go to Sewing Parts Online and do a search under Singer Service Manuals; if they don't have it in stock, call or email them and they will be happy to order it for you. Generally takes two weeks to get it in stock.
Apr 10, 2015 | Singer 20u Sewing Machine
Pfaff 6091 Presser foot won't go all the way down
HAVE THE 6091 MACHINE AND THE FOOT IS NOT FROZEN BUT WON'T GO DOWN. OILING THE MACHINE DID NOT HELP AT ALL. HAD A REPAIR MAN COME TO THE HOME AND CLEAN THE MACHINE. STILL THE FOOT WILL NOT GO DOWN.
Nov 21, 2011 | Sewing Machines
The foot doesn't go down enough to reach the feed dogs
The presser bar may be stuck and may need some WD40 on the top so it seeps down the needle bar, or the presser foot dial or adjuster is set to 0, or the presser bar spring has broken, or the block and screw on the presser bar where the lever is has come loose.
Sep 02, 2011 | PfaFF Sewing Machines
Brother ps 33 material will not feed through machine
Are the feed dogs up and working?
Is the presser foot down?
There should be an adjustment somewhere on the top of the sewing machine, above the presser foot where you can adjust the pressure of the presser foot - left for less and right for more.
Is the fabric under the presser foot when you begin sewing?
Feb 19, 2010 | Brother Sewing Machines
Thread tangling up under guides at bobbin area
Remove the thread from the machine and rethread it . Raise the presser foot before you pass the thread through the tension assembly. Do a tension test.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Tension assembly test. To do this test. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.)
If it doesn’t work this way then you probably have a piece of thread or lint stuck inside the tension discs. To remove it, turn the tension to 0 zero and raise the presser foot.Using a small screwdriver, open the space between the discs and spray with canned or compressed air. The stuff should come out. Do the tension test again to make sure you got everything and then try sewing again.
Normally, what you are describing is a threading problem or a tension problem.
sewman7
Mar 19, 2009 | Sewing Machines
Sewing Machines Logo
138 people viewed this question
Top Bernina Sewing Machines Experts
Vernon Taylor
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
