2005 Chevrolet Equinox Logo
Dean Gammon Sr. Posted on Jun 05, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2005 Chevy Equinox Power Seat Switch Diagram!
jack layton
Level 3:
  • Chevrolet Master 5,569 Answers
  • Posted on Jun 18, 2016
jack layton
Chevrolet Master
Level 3:
Answers
5569
Questions
0
Helped
2397940
Points
20059
You see the circuit breaker, supplies voltage to power seat switch, You see the wire color? On hinge side of driver door is probably a wiring harness, probably has a protective rubber boot covering. Pull the boot back far enough to see wire colors, use a testlight, have to penetrate the insulation to get at the wiring. If no voltage, either wire is broken or check for voltage at the circuit breaker. Black wire is ground, check that also.
You see the wire colors for seat motors, those are voltage and ground, depending on which way the motor is moving.
2005 Chevy Equinox Power Seat Switch Diagram! - 26212729-z33rarn03reygqwbcbj0ismt-4-0.jpg
5 Related Answers
Anonymous
  • 25 Answers
  • Posted on Apr 05, 2009
SOURCE: where and how to change cabin filter chevy equinox
Hiya...the cabin air filter is located below the front passenger/windshield area.
It's only accessible by standing outside the Equinox with the hood open.
Here's how to do it...(before you pop open the hood)
1) Stand outside at the front-right door area.
2) Just below the front windshield area, pull up a few small black plastic clips that's on the black windshield wiper cowl area- a small flat screwdriver or a special clip-remover tool is handy.
3) Raise the hood up.
4) There may be a triangular-shaped hard foam sound damper at the left side nearby the hood hinge...pull it off if it allow you to work around it with ease.
5) Continue to find a few black plastic clips around the black windshield wiper cowl area.
6) Gently pull up the black windshield wiper cowl cover with care not to bend it too hard during removal.
7) You should see the cabin air filter inside that's held in place by a black rectangular box inside.
8) There's 2 black tabs that holds the cabin air filter in place.
9) Insert your finger or tool to pry the cabin air filter away from the tabs.
10) Remove old cabin air filter.
Remember to reinstall the clip parts back into place when you're finished.
george parkes
  • 980 Answers
  • Posted on Apr 08, 2009
SOURCE: 2005 Chevy Cavalier Electric Window Wiring Diagram
Tom,
See this alot. Sorry,It appears that is a symptom of a bad motor. If it moves an inch or so,then nothing,after a few minutes another inch or so,it's motor time!
Robert Sonmor
  • 58 Answers
  • Posted on Nov 07, 2009
SOURCE: WHAT IS THE REDUCED POWER LIGHT ON AN 2005 CHEVY
It means that there is a problem in your throttle actuator control system.The PCM will limit power until the problem is resolved.You should probably take your vehicle to a GM Dealership for further diagnosis.
Anonymous
  • Posted on Mar 28, 2010
SOURCE: 2005 chevy equinox rear hatch not locking
I've had the exact opposite issue with my 2005 Equinox.
My rear door is locked and will not unlock.
Anonymous
  • 4793 Answers
  • Posted on Jul 09, 2010
SOURCE: 2005 Chevy Equinox, LT
at 60k, if it aint been done,do the lot.....filters oils.....antifreeze.....belts.....timing belt. then you have another 60k before you have another big bill.....
Testimonial: "Thanks for the help. I didn't realize that it would need a timing belt so soon."
Chevy equinox wiring diagram
google Chevy equinox wiring diagram and images will come right up
Need a diagram of the ac system for a 2005 chevy equinox
Need the wiring diagram for a 05 Chevrolet equinox
3helpful
4answers
Chevy Equinox light on on the dashboard
This is you Airbag Readiness light. On start up, it should come on briefly while the vehicle goes through it's check and then go off.
If the light stays on when you're driving, have the system checked immediately. There is a possibility that a malfunction could actually deploy the airbag. It's important to have it checked.
14helpful
3answers
I need a diagram of a 2005 Chevy Equinox engine
where is the coolant temp sensor on a 2005 chevy equinox
3answers
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
