Question about HP LaserJet 3055 All-In-One Printer
WIA scanner driver for HP laserjet 3055
Where can I get a WIA scanner driver for a HP laserjet 3055
Posted by Ivan Steenkamp on
Sanjeev Singh
    Habit-Forming:
  • 55 Answers
Http://h20564.www2.hp.com/hpsc/swd/public/readIndex?sp4ts.oid=1140612
Posted on Jul 05, 2016
5 Related Answers
Anonymous
  • 105 Answers
SOURCE: How to reset an HP LaserJet 3055
If you go in your user manual to page 241, it shows the following instructions on how to reset the printer to factory defaults. One important note is that you will lose EVERY stored piece of information including phone numbers and such.
To restore the factory-set defaults
1.
On the all-in-one control panel, press Menu.
2. Use the < or the > button to select Service, and then press .
3. Use the < or the > button to select Restore defaults, and then press .
The all-in-one automatically restarts.
Hope this does it for you.
Posted on Jun 19, 2008
Anonymous
  • 107 Answers
SOURCE: HP LASERJET 3055 . I LOST THE DRIVER CD
if u want Drivers for Hp 3055 all in one please use below link for Drivers
in this site please Select correct Operating System witch u have on u r system after Selection u get All drivers & softwares for This printer also available Frimware for it
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=1140780&taskId=135&prodTypeId=18972&prodSeriesId=1161389&lang=en&cc=us
if this Information is useful for u please Rate me........
Posted on Jun 24, 2008
Anonymous
SOURCE: Scanning on HP 3055 printer/scanner/fxx doesn't wrk with vista
I am unable to scan in pdf format under vista window
Posted on Mar 23, 2009
Anonymous
SOURCE: Hp 3055 laserjet scanner problem
When powered on printer 3055 it gives error on control panel that
"Scanner error 6 Trun off and then on "
after several restart printer gives the same error
what will be the problem
Posted on Sep 04, 2009
How to fix scanner error 6?
herewith 3 suggestions (try searching the HP forum or search engine 'scanner error 6'). Read all of them before you decide to do anything and only then decide which order if any to do them depending on ease vs likely effectiveness.
HP LaserJet 3055 Scanner Error 6
HP Laserjet 3055 Scanner Error 6
6.July.2015
Jul 06, 2015 | HP LaserJet 3052 All-In-One Printer
I am not able to scan the hp 3055 scanner. i got Twain compatability problem. so how can i solve the problem
Hi
Dear Remove your Hp driver for your Add/Remove Program and install again, may be your scanner  driver is corrupt.
For the driver please click hear select your Operating system and download the driver.
Good Luck
May 25, 2011 | HP LaserJet 3055 All-In-One Printer
Printer Hp Laserjet 3055 giving error message 5
If you scanner error 5 or printer hangs at scanner bulb warming up than the issue is with Scanning Assembly inside the printer and it is hardware issue.
Apr 12, 2009 | HP LaserJet 3055 All-In-One Printer
HP laserjet 3055 all in one Scan problem
which OS are u using ?
try uninstall and reinstall the driver from the cd itself
Oct 31, 2008 | HP LaserJet 3055 All-In-One Printer
HP 3055 does not see device as a printer, just a fax/scanner
Do you have proper print driver loaded? I suggest using online diagnostic tool available through hp.com. This tool will troubleshoot problem and suggest appropriate driver, if necessary.
Sep 24, 2008 | HP LaserJet 3055 All-In-One Printer
HP Laserjet 3055 with "scanner error 6 - turn off and on" error
hp laserjet 3055 by scanner error 6
Solution: I found a very small piece of paper between the glass and the scanner housing. The lamp's seen that and sent the error message. Nobody find that little stucked paper and the "IT expert" sad: need to buy a new machine because he can't repair it. So, sometimes the solution is very easy just need some attention. :)
Apr 27, 2008 | HP LaserJet 3055 All-In-One Printer
Dec 20, 2007 | HP LaserJet 3055 All-In-One Printer
3055 scanner not working
My HP 3055 cannot scan but can print & fax.
Nov 02, 2007 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
341 people viewed this question
Ekse
efs_perpends
efs_perpends
