Question about Canon PIXMA MX410 - multifunction fax / copier / printer / scanner color
Fax machine just keeps telling me to re-enter the number
Will not fax
Posted by paul hurley on
1 Related Answer
Anonymous
  • 59 Answers
SOURCE: Sending a fax from my L80 to an overseas fax machine.
overseas calls must use 011 then the country code 866 then teh city code then the fax number . Do not dial starting with a 1 otherwise you will be calling in North America
Posted on Feb 20, 2008
Hi, I have a Toshiba e-studio 170f fax machine, can you tell me how to programme numbers in for speed dial? Thanks.
Assume u want One touch dialing:
Display Tel. List Menu-->Group Numbers(3)-->Press One Touch(2)-->Enter your desire 1 touch key (e.g"1")-->Enter fax number
May 27, 2011 | Toshiba E-Studio 161 Copier
My hp 1040 will not pick up fax after the fifth ring answering machine picks after forth ring can't tell the between phone call or a fax used to before changed date on answering machine fax quite working
Set rings to answer
You can select the number of rings that will occur before the fax answers an incoming call. If you are using your machine as both a telephone and a fax machine, we suggest you set the ring count to at least 4 to give you time to answer.
TIP: HP 1050 Fax: The Toll Saver function for the Digital Message Center interacts with Rings to Answer. See Toll Saver on page 40. If you have the HP 1050 Fax and have Toll Saver turned on, set the Rings to Answer to 2.
1. Press Menu repeatedly until BASIC FAX displays and press Start/Enter.
Rings to Answer will display.
2. Press Start/Enter.
3. Enter the number of rings you want (2-7) and press Start/Enter.
The HP Fax rings the set number of times and then answers. It then produces a different sounding ring to alert you to which type of call is incoming.
• The additional ring may occur once for a fax call
• The additional ring occurs 5 times for a voice call. After the 5 additional rings, the answering machine will answer.
Dec 08, 2010 | HP 1040 Plain Paper Inkjet Fax
My H P fax machine is telling me to push enter to
Hi Dennis,
You must replace all ink carts to get a sucessful alignment.
Dec 26, 2009 | Office Equipment & Supplies
We have the intellifax 4100. It keeps telling us
Hi Sandy58 this is the fix. all you have to do is: open the front cover (leave it open) and press the clear button then it will ask you NEW DRUM AND YOU ENTER 1 FOR YES and that's it good luck.
any other question please email me,
thank you.
Mar 19, 2009 | Brother IntelliFAX 4100 Laser Fax
How to save fax numbers
press Function
72
set
1 for ONE TOUCH NUMBERS
set
press 01 on the soft pad
enter fax number with the DIALING NUMBER KEYS
set
enter name with LETTERS on the soft pad
set
continue with 02, 03, 04 etc.
when done press stop.
press Function 67
set
cut out directory sheet on dotted lines and put under the mylar sheet on the soft pad.
press Function 62 set to print out the list of one touch numbers.
Nov 19, 2008 | Panasonic Panafax UF-560 Plain Paper Laser...
Faxing to several numbers
Sending Broadcasting Faxes:
Using the BROADCASTING BUTTON on the control panel you can use the broadcasting fax feature. 1. Load the document(s) face down into the ADF. 2. Adjust the document resolution to suit your fax needs.Press BROADCASTING on the control panel.4. Enter the number of the remote machine using the number keypad. 5. Press enter to confirm the number.The display ask you to enter another fax number to send the document. 6. To enter more fax numbers, press 1 to select "YES" and repeat steps 4 and 5. You can add up to 10 destinations. NOTE: You cannot use group dial numbers for another fax number. 7. When you finish entering fax numbers, press 2 to select "NO" at a "ANOTHER NO" prompt.
The document is scanned into memory before transmission. The display shows the memory capacity and the number of pages being stored in the memory.
The machine begins sending the document in order of the numbers you entered..Hope this helps
Oct 08, 2008 | Samsung SF-560 Plain Paper Laser Fax
Fax machine not sending or receiving
First of all have you pluged a phone into the phone cord of the machine ? Just to verify the phone line.
Is your phone number and ID entered into the machine?
If that information was somehow deleted, that has to be reentered for the fax machine to work. Thats a legal thing.
If the phone line is fine and your ID is properly in the machine and it still is not working then you have a bad fax modem board.
hard to tell you much more without knowing the make or model number.
Apr 22, 2008 | Office Equipment & Supplies
Fax
An access code is normally set up by a person or company to prevent long distance faxes or phone calls by unauthorized users. The access code is a series of numbers to access long distance service. Check with your employer for the long distance code or check with you carrier to make sure that this service has not been put on your line by mistake.
Oct 08, 2007 | Brother IntelliFax-2820 Laser Fax
Canon PIXMA MX410 - multifunction  fax / copier / printer / scanner   color Logo
137 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
