Miki Posted on Jun 04, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My question laser jet400pro m401d eror 50.3 - Laser Office Equipment & Supplies
Electro Med Services
Level 3:
  • Laser Master 6,694 Answers
  • Posted on Jun 04, 2016
Laser Master
Level 3:
Answers
6694
Questions
Helped
1870099
Points
21433
If you wish to get some details; check the site linked here. Pull up older posts....
http://electro-medical.blogspot.com/
What is Error Code:59.A0 for Hp laser jet 400 M401d?
59 error indicates a main motor failure. This if often caused by a jammed cartridge, so trying a new toner cartridge would be your first step to trouble shoot this.
What is Error Code:59.A0 for Hp laserjet 400 M401d?
A main motor error occurred. X description: 0 = Motor error 1 = Motor startup error 2 = Motor rotation errorA main motor error occurred. X description: 0 = Motor error 1 = Motor startup error 2 = Motor rotation error HP LaserJet Error Codes 50 59 Looks like a motor error check the fuser unit and drum are seated properly.
Conon ir 2520 erore code e000750
E000 errors are usually a bad fuser (also called fixing assembly by canon) You should buy FM4-3367-000 (for US/ Canada / Mexico 110V version.
Eror c2656
no such code for A c450P
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Eror 52.0 scaner eror
The 52 error in most HP printers is not reversible, you must replace the scanner if the is cost worthy.Might want to unplug printer from the power source for 30 minutes and retry, before changing the scanner unit.
3helpful
Xerox 7400 toner superposition problems
When the colors do not align properly you need to clean the LED printheads. Full instructions on how to do this are located at:
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=110,E=0000000001181486662,K=5398,Sxi=19,Case=obj(1219)
Top Laser Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ADMIN Andrew
ADMIN Andrew
Are you a Laser Office Equipment and Supply Expert? Answer questions, earn points and help others
