Question about Home
No outdoor display on clock
I replaced my old batteries in clock and outdoor sensor. Since doing this my clock will not display the outdoor temperature. I tested the batteries and they are fully charged. Does anyone know what the problem might be?
Posted by Judy Frederick on
Lee Parker
    Habit-Forming:
    New Friend:
  • 108 Answers
Check the outdoor sensor to make sure the batteries are installed correctly. If they are and it is not working, check for corrosion or bent contacts in it. Clean them or adjust them as needed. If they look ok the outside unit may need to be re-synched with the inside one, or it may just have gone bad.
Posted on Jun 03, 2016
Replacement Outdoor Temperature Sensor for Atomic Clock
Search the manufacturers website and ebay. It may require a little time and effort.
Jan 02, 2018 | Home
I have the Atomic Clock model W86111. I had to change the batteries on the outside device. The clock outside temp just flashes 63.5 all the time. How do I make it sync to the device outside?
Remove all batteries from outdoor sensor and weather station.
Press one of the buttons on the weather station at least 20 times to clear all memory.
Verify that the weather station is blank before proceeding (there may be lines painted on
the screen that will show when power is removed).
Leave both units without power for 15 minutes (very important).
Insert fresh batteries into the clock.
Insert fresh batteries into the outdoor sensor.
Press the TX button on the outdoor sensor to transmit RF signal.
Keep the outdoor sensor 5-10 feet from the forecast station.
When RF connection is established, the temperature will appear on the station. Allow the
outdoor sensor and weather station to sit together for 15 minutes to establish a strong
connection.
Oct 14, 2017 | Home
OUTSIDE TEMP SENDING UNIT GOT WET AND WILL NOT CONNECT TO CLOCK. HOW CAN I FIX OR HOW CAN I REPLACE?
[PDF]WS-8117 ATOMIC CLOCK WITH OUTDOOR WIRELESS ...
https://www.lacrossetechnology.com/products/.../misc/8117-manual.pdf
NOTE: Do not set the clock until the outdoor temperature is displayed. .... The unit will still try and receive the signal every day despite it being manually set. ..... sunlight, extreme cold and wet/moist conditions as these will lead to rapid changes ... Beforesending the atomic clock in for repairs, contact La Crosse Technology.
La Crosse Technology Top Solutions
https://www.lacrossetechnology.com/support/top_solutions.php
A: Complete a restart for display with the temperature/humidity sensor: ... to rest for 15 minutes can result in failure to connect with the outdoor sensor or missing ... Products set outside of these time zones will not search for a WWVB signal as it is ... locate the Clock or Weather Display near an outside wall and point the unit in ...
Common issues weather stations: Click Here
www.weather-station-products.co.uk/faqs/common-issues-weather-stations
Under £30 £30-£75 £75-£125 From £125 Birdhouses/Feeders Outdoor Clocks ... I'mnot getting any outdoor readings from my outdoor sensor, what do I do? This willcure 90% of all sensor connection problems, important you must ... is the airtemperature, to get this reading you need to place the unit away from direct sun.
Replacement Temperature Sensor ' AcuRite
www.acurite.com > All products
Dec 16, 2015 | Audio Players & Recorders
La crosse support
Check the battery in the outside sensor. If the outdoor sensor is hard wired to the clock (or fresh batteries doesn't fix the issue) the unit needs to be replaced.
Jan 16, 2014 | Home
Lacrossetechnology
Hi Susuan,
One of these methods below should get your device working properly. Good luck!
LaCorosse Tech Support email address.
The product information page
From the manual:
915MHz RECEPTION CHECK FOR OUTDOOR TEMPERATURE SENSOR
The atomic clock will receive the temperature data within 3 minutes. If the temperature data is not being received 3 minutes after setting up (the display shows "- - -"), then please check the following points:
1. The distance of the atomic clock or outdoor temperature sensor should be at least 6 feet (2meters) away from any interfering sources such as computer monitors or TV sets.
2. Avoid placing the receiver onto or in the immediate proximity of metal window frames.
3. Using other electrical products such as headphones or speakers operating on the same signal frequency (915MHz) may prevent correct signal transmission and reception.
4. Neighbors using electrical devices operating on the 915MHz signal frequency can also cause interference.
Note:
When the 915 MHz signal is received correctly, do not re-open the battery cover of either the outdoor temperature sensor or atomic clock, as the batteries may spring free from the contacts and force a false reset. Should this happen accidentally then reset all units (see Setting up above) otherwise transmission problems may occur.
The maximum transmission range is 330 feet (100 meters) from the outdoor temperature sensor to the atomic clock (in open space). However, this depends on the surrounding environment and interference levels. If no reception is possible despite the observation of these factors, all system units have to be reset (see Setting up).
May 24, 2013 | La Crosse Technology Ws-8418u-it Atomic...
Remote sensor does not work after installing new batteries
Double check the batteries to make sure they are installed correctly. If one of the batteries in the outdoor sending unit is in backwards, it will not send the outdoor data. On the indoor unit, there is typically one battery that is used for receiving the signal from the outdoor unit. If all of the batteries are in correctly but that one, you will see the display and the indoor temperature information, but the outdoor information will not be displayed.
Oct 15, 2010 | ATOMIC Digital Wall Clock With Temperature
OUTDOOR TEMPERATURE
Please check the following website for all the info and faq.
http://skyscan.info/content/index.php?option=com_content&task=view&id=35&Itemid=40
Also,
If you have lost the outside temperature on the clock display after replacing the transmitter battery then do the following:
1. Make sure you have good batteries installed in the remote transmitter
2. Remove the batteries from the main clock and keep them out until the clock display disappers.
3. Re-install the batteries in the clock.
4. Wait until the display returns and includes the outside temperature display as well.
5. Set the clock again for current time/date etc.
6. Bingo. You are in business.
Sep 03, 2008 | SkyScan 86709 Atomic Wall Clock
3M Precision Digital Atomic Wall / Desk Clock with Indoor & Outdoor Temperature and Alarm will not display outdoor temp, i have replaced batteries, outdoor sensor is transmitting, does not appear to...
After replacing the transmitter batteries several times, I tried replacing the clock batteries. They must have been getting low. Once I put in new batteries in the clock it worked fine. Good Luck.
Aug 30, 2008 | SkyScan 86742 Digital Atomic Wall Clock
Home Logo
354 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
