An expert that got 20 achievements.
An expert that got 10 achievements.
An expert that got 5 achievements.
Master
Re: Hi. We are trying to setup a phillips tv through a...
A TV aerial feed - The BT Vision box gets its digital TV signals over-the-air, so needs a TV aerial. This needs to be connected to the aerial input socket on the V-Box. There is an output RF aerial socket to allow you to connect an aerial feed to a TV if required.
SCART lead - You need to make a connection from the Vision+ box to the TV using a SCART lead. If you have a HD TV set, you can also connect via an HDMI lead (not supplied).
Connection to Broadband - You'll need to connect from the BT Vision+ box to a BT Broadband connection. This is done using the BT Home Hub. The Home Hub is the Broadband router supplied by BT, and it connects into to your phone line to give you Internet access-The most common way to make the connection, is to connect an Ethernet (networking) cable from the BT Vision+ box to one of the Ethernet ports on the Home Hub. If you can't make a direct connecting to the Home Hub, you can use powerline adapters to make the connection. The self-install kit includes two Powerline adapters to allow you to connect to the Home Hub if it's in a different room to the BT Vision+ Box.
The BT Vision v-box has an additional scart socket, which can be connected to a video or dvd recorder.
Hi
I got my YouView box free when I signed up for BT Infinity (upgraded from standard broadband), and TV Essentials (replacing my BT Vision which had ceased). The link below will take you to a BT page which may help you, TV Packages And Deals Online BT
although I found it difficult to sort out what I would get on line and in the end rang them
Cheers
Freeview occasionally adds and removes channels. Sometimes, Freeview juggles some of the channel numbers around too. To make sure your box or digital TV has the correct channels and channel numbers, you have to rebuild the channel lineup.
If you wish to get more details about setup codes, and setup proceeding to many popular brand remote controls, check these links. http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the
brand name and model number to of your set, to its search box, and press 'Enter'
or view it in Mosaic / Timeslide option.
This system can only be used if you subscribe to BT Vision.
They have it configured so that Freeview only works once the box has checked your subscription.
I think this is a bit mean of BT because with their system Freeview is not free as you cannot access it without paying the monthly fee.
Im not 100 percent certain but I think duraband is the name that Asda/wallmart use on there kit.
You could try asking there customer services for assistance with this.
