Question about Tablets & eReaders
After 4 months my Fusion tablet won't turn on??
Posted by Brian Matthews on
scribbs
I have the same issue, and did everything you said but still nothing. Every 20mins on charge the logo flashes on and off... but it just won't start
Posted on Nov 12, 2021
guruaid_cs
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 906 Answers
To help you troubleshoot the issue, please follow the steps given below:
- If your device's battery is almost dead, you'll often see an empty battery indicator on the screen when you try to turn it ON. But if you let the battery completely die, your tablet won't respond at all when you press the Power button.
- To fix this problem, just plug your tablet into a wall charger and let it charge for 15 minutes.
- Now try to power it ON with the Power button, if the problem was caused by a dead battery, it should boot up normally.
- If it doesn't work at all, try plugging the device in with a different cable and charger. The charger or cable could be broken and preventing an otherwise-good device from charging.
- Your device may be powered ON and running but the screen won't turn on because the operating system is frozen and not responding to button presses.
- You'll need to perform a 'Hard Reset', also known as a 'Power Cycle', to fix these types of freezes.
- You'll need to long-press the 'Power button' of the tablet and hold it down for 'Thirty seconds' this will cut the power to your tablet and force it to boot back up, fixing any hard freezes.
Now check if your tablet works fine, if issue persists, please go to your device manufacturer website and see the instructions for performing factory reset or you can contact the manufacturer for further assistance.
GuruAid.com
Posted on Jun 02, 2016
I set my password on my fusion 5 tablet and I cannot remember it how can I get into said tablet?
you will after hard reset it you will loose everything type it in to youtube will show how to hard reset it
Zeepad does not open/reset to manufature setting
Hi Briditte, The link below is a YouTube video showing how to fix your tablet, Also there's video's down the right side of the link that may help as well....CHEERS..
https://www.youtube.com/watch?v=0PAB6khykWE
How To fix any Android Phone Tablet that won turn on
How do I fix my Fusion 5 tablet
How do I do a hard reset on my Fusion 5 tablet? - Android Forums ...
forums.androidcentral.com > Get Help & Give Help! > Ask a Question
Dec 31, 2014 - 6 posts - ‎1 author
hi, i have a fusion 5 tablet, thats all it says on the back so dont know much else on what its called, my tablet turns on but just stays on the. Chinese android tablet wifi problem
Mar 5, 2013
10.1 inch tablet ACHINGLY SLOW after ICS update ...
Oct 29, 2012
More results from forums.androidcentral.com ?
FAQ - Fusion5 - FUSION5 XTRA COMPACT Tablet PC
fusion5tablets.co.uk/index.php?route=information/information...id...
Fusion5. Frequently Asked Questions. Q. My tablet has frozen. A. This problem usually occurs when any specific app malfunctions so you need to perform a ...
A1CS Fusion 5 Stuck on Boot Up Screen ' Android Tablet Forum
www.androidtablets.net > ... > Android OS Forum > Ice Cream Sandwich
Oct 20, 2012 - 4 posts - ‎4 authors
My wifes did that and was suggested that i hold the on off button while pushing volume up (rocker button) , and that that would reset the boot up.
FUSION5 Extra - YouTube
? 1:15
https://www.youtube.com/watch?v=i4ihWLVMhCc
May 9, 2013 - Uploaded by MrOnka
FUSION5 Extra ... Theres nothing wrong with the tablet lmao you just don't know how to use one. why keep ...
Fusion5 10.1" tablet not responding ' TabletPCReview.com - Tablet ...
forum.tabletpcreview.com > ... > Windows Tablet PCs > Other Brands
Jun 24, 2012 - 2 posts - ‎2 authors
1helpful
Why won;t my irulu 10.1.1 tablet turn on. i push the button and nothing happens, when charger is plugged in it gets warm both tablet and plug
It sounds like you've done most of the things you would reasonably be expected to do to make it function; since it is only 2 months old I would strongly urge you to go back to the retailer and make them replace it or refund you, as your rights in most countries/states allow.
If you're set against doing this, try holding down the power and volume down key for at least ten seconds to see if this boots it into hard reset mode. If this doesn't do anything, try again holding down power with each of the other buttons to see if you can activate any other developer/reset modes.
However, I have read reports that this particular tablet has up to a 40% failure rate in its first six months.
If you can possibly get it refunded, do that and buy something else.
Why won`t my USB recognise android MID tablet
Is it going through a hub/switch. If so, try direct connect.
Kurio 7 won't hold charge. When pluged into charge it feels like it is seizing up and vibrates.
Don't most electrical/electronic equipment have a 12 month warranty at lest, Batteries 6 months, well here in Aus it's how I am aware it is. Anyway if you can and have warranty take it back, that's all I can suggest.
Tablets & eReaders Logo
Top Tablets & eReaders Experts
ADMIN Canada
ADMIN Canada
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
