Disconnect all the circuit boards from the power supply board and test the voltages again. If the voltages are correct, connect the other boards one at a time to see if one is dropping the voltage on the power supply. If you find one that lowers the power supply voltages to what you read before, that may be the problem board.
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Vizio TV No Image Black Blank Screen No Backlights Basic LED... Led drivers are on the power supply board. Here's a video
Yes go to SHOPJIMMY.com they will have vids on how to test and all the parts you may need. Good Luck
