SOURCE: Microwave won't work
F6 usually means a fault in the controller or keypad. You could try to unplug it for several minutes, then plug it back in. If it still fails, maybe you or a friend can disconnect the power cord, unplug the keypad strip internally, then plug the power cord back in and try it with the keypad still disconnected. If it does not fail again, you have a wet or shorted keypad and can dry it or order one. If it does fail again, the control board is bad. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383 Sorry I didn't get to answer this before the bogus answer was posted. I've been tied up and away from the PC.
SOURCE: Freak Out!!!
Correct on the ribbon cable but parts can be ordered for it, duel has service centers, inc the one i work @. its abought a $10 part
SOURCE: stuck dvd disc.
Hi there
Page 80 in the instruction manual tells you how to do this.
In case you don't have a manual, do the following:
While the unit is off, press and hold the stop key (shown on the unit as a button with a small black square on it) for about 5 seconds. It may take longer to eject depending on the disc.
Hope this helps
SOURCE: Jensen Phase Linear car radio
Take off the face plate and it is located in the lower left corner
SOURCE: AVIC-N1 opens to blanks screen and none of buttons work
It is probably the ribbon cable that you can see when the screen closes. This is a known problem and the part is sometimes hard to find. But is available.
