Question about John Deere Garden
John Deere L100
Starts but will not idle up.
Posted by Lisa Gillem on
Jim flowers
  • John Deere Master
  • 1,098 Answers
Sounds like the throttle cable has come loose. check it and adjust and tighten up.
Posted on Jun 01, 2016
Testimonial: "Has a brand new throttle cable it was 1 of the first things he checked.Thanks for replying"
  • Jim flowers
    Jim flowers Jun 03, 2016
    a new throttle cable is good but if not adjusted correctly it will not work
John deere L100 won't start after sitting all winter. what can I do?
squirt some carburetor cleaner in the carb. if it starts for a few seconds there is a fuel problem. sometimes water or debris will get in the carb and stop fuel from going through. take the bowl off and see if you see any of this in it if so clean it real good and it should run fine.
Apr 22, 2017 | John Deere Garden
John deere lawn mower
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
JOHN DEERE L100 L110 L120 L130 LAWN TRACTOR SERVICE TECHNICAL MANUAL TM2026
Mar 19, 2017 | John Deere Garden
How do I fix a drive spring on a john Deere L100
usually one would get a new spring and put on the unit .
Oct 19, 2015 | John Deere L100 Series
L100 john deere runs but has erradic idle, okay when blades engaged???
Never mess with the air adjuster .. If it was set correctly once It should never need messing with. Now you have another variable to the problem. More then likely the fuel Jet has some obstruction in it. Drop the fuel bowl and take the Jet out and clean it.
Sep 27, 2012 | John Deere 420,1020,2010,2020,2510,2520...
L100 John Deere mower will not engage...belt seems very loose but in good condition.
L100 has a tension spring on them it may have broke or came off. If i can help any further you may call me and i will help you. I worked for john deere for several years. (831)578-4034 thanks wade
Apr 08, 2012 | John Deere Garden
I have a john deere riding mower model L100 it runs good but after 20 o 30 minutes gas stop going to the engine after it cool down it start running again does this mower have a gas pump
When it dies loosen the fuel cap and see if it will start.If it starts its because the tiny vent hole in the fuel cap is plugged.
Jun 26, 2010 | John Deere Garden
Engine starts and runs Great. When I engage the Pto leaver on my John Deere L100 the mower fails.
at the point of lowering the pto it's trying tosuck more air to mix with the gas .you might just need to change the air filter.
Jun 07, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
66 people viewed this question
Top John Deere Garden Experts
Dennis Key
Dennis Key
john h
Are you a John Deere Garden Expert? Answer questions, earn points and help others
