Try installing a brand new needle. Sometimes a bent or dull needle will cause lots of racket.
You should consult your owner's manual for maintenance--cleaning and oiling instructions. Most sewing machines do require oil--some more frequently than others. Most machines also need frequent oiling in the bobbin/hook area. Be sure to use only good quality sewing machine oil for your machine--NO 3-in-1, WD-40, cooking oil, or old brown stinky oil.
If it continues to make the noise, you should probably have it serviced. Since it is less than a year old, it might still be covered under warranty, so don't delay.
I am trying to give a high score, but it's only letting me give a one. I want to say thank you so very much! The new needle only helped for a short time so I'm off to buy sewing machine oil! Hoping that helps! Again, thank you!!
If the oil on the bobbin hook doesn't help, take it for warranty right away. Don't let the warranty expire without getting it checked out!
Thank you R. A. Ellis! I'll be oiling it today, but since it's under warranty I have no idea where to take it for service.
Most likely a Juki shop. Or contact Juki manufacturer support.
Check bobbin size, maybe have you accidently put in a smaller bobbin? Different machines have different size bobbins.
