SOURCE: Hotpoint Ultima WD71(probably the wd72 except in white)
hi there what u can do is take your drain hose and place into a bucket water will come out the door will release now check the pump and make sure that it is not blocked up with anything if it isnt check the drain pipe that is under the washer in the middle of the drum there will be water in there but check inside if anything is inside there it will slow down the empty programme and will not let the door release do u live in malta then m8 as my dad is maltease and im half
SOURCE: It does not open
turn the machine off at the mains, after two minutes the door should release from the auto lock, but your pcb (printed circuit board) is knackered start saving.
SOURCE: Door locked
After trying all the above, making sure that as much of the water has been removed as possible, you can always use the manual door release. This is located behind the soap powder tray.
Push to open as you would normally when adding more soap powder, pull the tray out as far as you can.
Press down on the yellow portion in the tray and this should enable you to then pull the soap tray completely out.
Once out you should see what looks like a small grey plastic circle with a rectangular hole (ideal for a screwdriver) turn this and your door should open.
SOURCE: Cycle finished but door won't unlock, please help
normally, front loading machines have this bypass cables in case this things happens, if there is a small opening at the front to acces the drain filter, open it up then look for a small plastic pc with a ring at the end. this is the pull release cable of the door lock. pull it downwards and the door will be released.
if you do not have the small opening to access the drain filter, you can tilt the machine to its back, ( be carefull, its very heavy) then reach for the plastic ring underneath to pull to release the door lock.
tnx 4 using fixya..
drcool
SOURCE: Hotpoint WML560. door release wont work after wash
my niece pressed all the buttons on the machine now it will not start any cycle
