How does the pressure switch works,i know the water fills up the tube and activate the switches inside the pressure switch,but how does it know if its very low or low,mid or high load...pl help
That would be a bad repair, if you attempt it I hope your home owners insurance will cover you for the flood:
Washing Machine Repair How to Test the Water Level Switch
Appliance411 FAQ Washing Machine Water Level Control Operation
Washer Water Level Switch part W10337780 How To Replace
How water level switch works
Testimonial: "hi gil shults,just wanted to do a quick fix until i can afford to buy the pressure switch..im a millwright by trade so i do understand how contacts work,and from what i read about pressure switches its has a n/o and n/c set of contacts..when the water fills inside the tube in opens the n/c thus cutting off the water and closes the n/o allowing for the was cycle..the pressure switch has 3 wires coming out 1 is com that voltage is supplied the other 2 should be n/c and n/o..if you could can you please how the washer knows my wash load level.. ps....not going to leave the washer unattend..many thanks deon"
The pressure switch has a tube that is open and goes into the water out of the washing area. As water rises in the tank it raises the pressure on the switch, when it reaches a preset level it trips. What you are asking I think the switch with the three contacts is a safety switch there is probably another switch to control the level or it could be done with a timer, both methods are used.
