Why I can't send or receive photos with sms
I have to go to Gallery, go to the photo I want to send, select Share, then select the Messaging app. On my Messaging app there isn't a way from selecting a photo.
For receiving photos, see if they are automatically put in your folder, like contact info is put directly in your contacts list without even opening the message - and if you did open it, it would show a blank message.
There are actually multiple possible issues that are occurring. First, if you are using an iphone you need to make sure that the sms settings are enabled under your messages section in the phones settings. If you are using anything else you may have the incorrect apn settings installed. Google " APN settings for (device) with (carrier). Third your carrier may be having a network issue.
Hello when we talk about send or receive photo on message we don't talk about SMS en thes case its MMS ok if you have any problem about send or receive MMS its sample cous you should set you phone settinge to seport MMS if you talk whit the company they will send you a configuration sms to set automatcly the service
SOURCE: sending an sms
try resetting the service centre number and make sure you do not have active diverts enabled
SOURCE: sms sending failed
soft ware is not corrupt it is a miner problum.
there is messege setting
u will c there other setting
there is sms center no.
u miss that no.
wich coumpani cell u used all companies have different no of sms center ok
put the currect no
SOURCE: I cannot send sms in my Motorola c261
Check that your Band Setting is correct.Press the centre key then >Settings>Network>Band Selection>900/1800 or 850/1900.Your band setting is dependent on your region.Set it accordingly.I hope this fixes your problem.
SOURCE: automatically sms and mms sending
yes you can solve this by pressing *#7370# it will format your phone to default settings.
and note there is a virus in your phone.
Good Luck!!!
neo
SOURCE: cannot send SMS, but can receive same.
This is a common problem that lies in a number that is stored in your phone. Most providers call this the "Service Center Number". It can be found in your messaging settings. Just call your provider and they can walk you through putting the correct number in the phone. Keep in mind that whatever number they give you, you should have a + in front of it.
