whats everything -- also check fuel pressure new doesnt mean free from defects this link and quite a few 610 owners have been complaining about same problem for years but go through test and check the basics first--plugs -wires-filters-oil level --wiring --carb settings --battery https://www.quadcrazy.com/atvforum/topic/14998-2005-kawasaki-mule-610-sputters-going-uphill/ also this link has service manual download https://www.utvboard.com/files/category/11-kawasaki/ https://www.utvboard.com/files/category/11-kawasaki/
Full tune up and carb clean .get new plug,air filter.oil Chang ,carb clean and adjustment.that should do it.,., try fuel filters and test fuel pump see if it's functioning properly.,.
Air leak .dirty air filter.,.fouled plug.,.bad gas.,.dirty carb?fuel injection? Bad fuel filter ,fuel pump test fuel pump that's the general stuff.go from there
I have an 88 Mule with the same problem. I thought maybe the float level was wrong but I cleaned and checked the carbs and it made no difference. I question fuses because it runs fine forward. There is a wire from the neutral/reverse switch going to the icigniter so I'm wondering if it is related to that. I'm sure someone has fought this problem. Thanks for the help.
