Jul 7, 2014 - Please remove foreign objects so that the print head holder can move: ... closet and hooked it up this morning, I was getting the 5100 message.
There are several reasons for error 5100 to appear. ... If the above recommendations donot help you resolve the error, the printer will need to be repaired.
? 2:23
https://www.youtube.com/watch?v=rJQVwwRxPv4
Mar 14, 2013 - Uploaded by ITJungles
Learn how to fix the Canon printer error 5100, and have your printer running again. ... Reset error Canon ...
Hi Andrey,
Did you mean P02?. If yes, means that carriage error occurs on your printer. This error is another format of error code 5100. It describes the same thing that applicable for all Canon inkjet printer model.
I hope the following link would be useful for you. Thanks.
Hello!
This error meams that you have a communication error modem.
This may happened after a instalation. Did you install a new fax board?
Make sure that the fax board are well instaled. It have a jumper that needs to put it ON.
If this does not helps reply to me and give more info.
Error F 20 means "No Water Detect" error.It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed.
You'll need to check for the following--
1- Check the Inlet water valve if it is clogged. 2- Make sure water taps are working fine. 3- Check inlet hoses for kinks or clogs.
Error code 5100 /this error is an error within the printer. This error means that there is
something obstructing the printing process. Check inside your printer through the gears that
you can see under the lid. There should be something obstructing the gears such as dirt or
in my case popcorn. Check VERY thoroughly.
it simply means it fails to complete the self test program upon power up. This could be most mechanical, a miss aligned gear, loose or dropped drive belt or foreign material accidentally dropped inside. Opening the cover and examin the mechanism may just spot the problem.
