Dishwashers Logo
Question about Fisher Dishwashers
I have a fisher Paykel dishwasher and a e20 code came up does this mean it is blocked
Posted by Vivianne Andreasen... on
Paul
    Sergeant:
  • 225 Answers
Hi Vivianne
I found the definition of some error codes but I don't know if any of these will apply to your appliance:
Fisher Paykel Fault Codes
I hope this helps
Posted on May 29, 2016
1helpful
2answers
I have DW60CDX2 , Turning on but buttons are not responding when I pressed buttons?
from what I'm seeing for the dishwasher, an E1 error means that the door is not properly closed. So, please look at the door of the machine to make sure that nothing is broken or that the dishwasher isn't too full. Thank you.
1helpful
Hi, how do I fix error code F1 of a fisher & paykel draw dishwasher??
The F1 error on a Fisher and Paykel dishwasher means the flood switch was activated for seven seconds or longer. ... The dishwasher's flood switch could activate because the water is leaking around the heater plate. It would still eventually show up somewhere, though a leak like that would kill the heater plate too.
My dishwasher is not working and has an error code of F2. How can I fix this problem?
F2 means that your rotor isn't moving properly and will need to be replace or it needs to be removed and check for something blocking it. Below is a link to a video that will show you how to take your dishwasher apart and repair your Fisher and Paykel unit.
Good luck.
1helpful
What does F2 mean??
F2 means that your rotor isn't moving properly and will need to be replace or it needs to be removed and check for something blocking it. Below is a link to a video you can buy for only $3.99 that will show you how to take your dishwasher apart and repair your Fisher and Paykel unit.
http://www.appliancerepairlesson.com/shop/dishwasher-videos/fisher-paykel-dishwasher-repair/
1helpful
U1 code 920 model filter is clean no hoses bent or kinked ? can it be fixed ? hans
The U1 code means:-
Dishwasher attempted to fill to correct level but failed. = Water tap not turned on. Turn the water tap on.
Too much foam. Rinse aid setting too high or has been spilled. = Turn the rinse aid dial to a
lower setting or wipe the spill. Incorrect detergent. Ensure that you use a detergent that is intended for a domestic automatic dishwasher. Egg yolk. Place an extra tablespoon of detergent in the dishwasher door for pre-rinsing.
Too much detergent. Use the recommended quantity of detergent
Wash pump faulty. Call your Fisher & Paykel Dealer or Authorised Service Centre.
Dishwasher not draining. = Drain hose bent or kinked. Straighten drain hose so water can flow through. Strainer blocked. Empty out the strainer and ensure the filter plate is clear of food
particles..
2helpful
F9 problem code Fisher and Paykel Dishwasher - Soft Touch
That's an electronics failure code. Bad news.
http://www.advantagesupplyfl.com/FisherPaykelDishwasherFaultCodes.html
3helpful
Fisher and paykel diswasher f1 fault code
f1 fault code means the flood switch is activated. There is moisture at th e base of your dishwasher.
5helpful
2answers
Hi Both drawers show error F1 flashing beeping with rinse light on and both pumps run after power is applied to machine
F1 error indicates flood switch in base has activated, meaning machine has leaked. This causes machine to drain continously, and can only be stopped by switching off power. Not easy to fix if you don't have experience- bottom drawer has to be removed to access flood switch, then machine needs to be test run and checked for leaks. Best to call the professionals!!
Open Questions:
Top Fisher Dishwashers Experts
vince
Paul
NOEL
NOEL
Are you a Fisher Dishwasher Expert? Answer questions, earn points and help others
