Just to make a note, the RCA 4k UHD TV models such as RTU-**** are horrible for finding remote codes. These TV's are actually made by Curtis. The manua will give you the remote code.. sort of. So far it seems as though all of them are NEC format with a code of A05F .. along with a full key map.. useless for a universal remote, useful for a Windows ore linux serial based IR transmitter.. and maybe a lead to the 5 digit code. NEC codes did not work, seems to be NEC format, which covers 95% of all remotes, NOT NEC product.
I have one of this tv model too.Just used a RCA component cables like Y,R,W hook one side to the tv Video IN INPUT holes and the VCR the other end of the cable to VCR Video OUT INPUT holes.Now just pushes a channel manual button up or down a couples for the tv go into VIDEO Mode.Play the dvd player it will work.Or try Remotes.com to buy a tv original remote.Return the universal remote.
I own a One-for-All universal remote, and my booklet says the setup code for a Curtis Mathes TV (without a built-in DVD or VCR) is one of the following numbers: 0030, 0047, 0054, 0060, 0093, 0145, 0154, 0166, 0451, 0702. I can not guarantee these numbers will work with your remote, but it is worth a try.
We also bought a universal remote to program a Curtis Mathis TV. We found the code by using the code search method. It works everything but the channel program feature. Does anyone know how to access that? BTW the remote is a GE 24921. Thanks
I have found some Curtis codes you can try. 00, 06, 11, 15, 21, 50.
If those do not work, does the cable remote have a "learn" function?
This is where you point the cable remote at the TV remote face-to-face & press all of the pertinent buttons on TV remote in order for the cable remote to "learn" what codes th e TV remote is generating for the various control functions. If the cable remote does have this function the users guide will give you step-by-step instructions. Barring that contact your cable provider.
Keep in mind that there are so many TV models being produced by numerous manufacturers these days that it maybe possible that your model's remote codes are not compatible with anything than another Curtis product. You may have to contact Curtis directly.
