Question about Zapco Car Audio & Video
Is there a power and audio plug pin out for a zapco peq available
Posted by kenny kendall on
Lawrence Oravetz
  • Zapco Master
  • 10,548 Answers
Try their website or a youtube video.
Posted on May 29, 2016
Install my amp
Go to this link and see page 47
http://www.zapco.com/files/Download/DCRef.pdf
Jan 18, 2013 | Zapco Reference 650 Car Audio Amplifier
How many rms does my amp have.....??????
4-channel, 4 ohms: 4 x 50 Watts
4-channel, 2 ohms: 4 x 90Watts
Stereo, 4 ohms: 2 x 180 Watts
T.H.D. : Frequency Response: 10 - 25KHz
S/N Ratio: >90dB
Channel Separation: >50dB
Dimensions: 13"L x 9.9"W x 2.25"H
Zapco I450 Zapco I 450 iForce Series 4 Ch. 360 Watt Amplifier
May 22, 2011 | Zapco I-450 IFORCE SERIES 4 CHANNEL CAR...
I need a manual for a zapco PEQ 9 band (old school) equalizer. can you help me?
i got a wiring paper that comes with the peq plug,its not a manual but it shows how to wire up a zapco peq
Nov 07, 2010 | Zapco Car Audio & Video
I have a zapco model PEQ board and i need the cable/wire wiring instructions can you help me?
The plug consists of a 7 pin plug which contains a ground, a hot lead for the PEQ itself, a neutral for the PEQ, and a hot and negative for each L and R channel, respectively. I had mine changed to RCA's years ago by a local shop, then soldered the connections myself after the proper connections were changed at the shop. I now have the signals changed into a Symbi-Link Transmitter/ Reciever System (unbalanced to balanced inputs) and am able to de-tune the PEQ and still get more output. It's fun... Hope the info helps.
Jun 01, 2010 | Car Audio & Video
...storing noise detected from my
Storing as in Distortion? If that's the case lower the output gain from your amp until it is suitable to you ears. It might be all the way open, besides this should be adjusted system to system.
May 31, 2010 | Zapco Reference 650 Car Audio Amplifier
Zapco ag 350
Check your ground and make sure it is properly grounded ....it needs to be a very clean paint/gum free area tightly bolted.  Next Check and make sure you are recieving your 12 volts (not running)  13 (running)    by placing your test leads from positive to ground...... then make sure your power remote from your head unit is putting out voltage.
Aug 23, 2007 | Zapco Reference 200 Car Audio Amplifier
ZAPCO 9.0
Go here first http://www.zapco.com/ Good Luck
Aug 06, 2006 | Zapco C2K-9.0XD Car Audio Amplifier
Car Audio & Video Logo
232 people viewed this question
Top Zapco Car Audio & Video Experts
Marvin
Marvin
Are you a Zapco Car Audio and Video Expert? Answer questions, earn points and help others
