Question about Dewalt Drills
What can cause this issue
I have a Milwaukee m12 impact driver and I absolutely love it the torque is comparable to my 20v dewalt unfortunately the last couple of days I can not get my batteries to charge the charger shows the solid red light indicating that it is charging unfortunately that's the extent of it I can leave it on the charger for 8 hours and if still only shows the red light and put on the impact it gives me the same charge level as when I put it on the charger
Posted by Kyle DeLory on
J.D. Browning
  • Dewalt Master
  • 2,760 Answers
If the battery is older than 1 year replace the battery with a new one , also I know its difficult but try to not charge a battery till its dead , short cycle charging of battery's kills em fast if battery is less than 1yr contact Milwaukee its still under warranty
Posted on May 27, 2016
Testimonial: "The impact was new at Christmas time last year I do not short cycle charge the batteries I run them until they will no longer turn the screws but will still barely turn the Chuck with no pressure and this is happening with both of the batteries that I have and happened at the same time very odd"
Battery compatibility : drill DCK277C2m and battery DCB205
No it only fits the models it is designed to fit. Go on eBay to check this.
Aug 22, 2017 | Dewalt Drills
My dewalt impact gun dcf885 when I press trigger the motor starts then dies
Mick, this could be a sign of a worn out/faulty motor, mine did this, ripped it apart and it was the motor. Yours may still be under 3 year warranty if you can find your receipt.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
DeWALT DCF885C2 Type 1 20V Impact Driver Parts
http://www.mmtoolparts.com/store/dewalt-impact-driver-parts
http://www.dewalt.com/en-us/legal/warranty/general-warranty-information
DEWALT ServiceNet
Jun 13, 2016 | Dewalt Drills
Torque adjustment collar very difficult to turn
try spraying some lube like WD-40 in the chuck as it is faceing up and let it set overnight it may got some moisture in it . hope this helps.
Jan 17, 2016 | Dewalt DCF885 20V Max* Lithium Ion 1/4"...
How to repair dewalt 20v impact drill .Spring to hold adapter has broken
N078434 part pos 12 if its handling this impact model important to get for the right model see link
Detail
Sep 07, 2015 | Dewalt Drills
Thank You for the response.I guess I need a air Impact wrench instead of the DeWalt Electric
Or compare before with 18Volt Milwaukee FUEL impact wrench on Li Ion Battery [ try before you buy ] its having very much power.
But if you have work the whole day job the best choise for long lasting air tools
Mar 06, 2015 | Dewalt Tools & Hardware - Others
I dropped my dewalt 20v impact 2 stories n now it
Take it back to the store where you bought it. If the warranty will not replace it, buy a new one.
Oct 14, 2014 | Drills
Dewalt dcf885 will not lock the bits in
It could be the little spring at the back of the chuck sleve is broken ot one of the locking balls is missing.
Apr 01, 2013 | Dewalt DCF885 20V Max* Lithium Ion 1/4"...
Drills Logo
455 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
efs_perpends
efs_perpends
Mike
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
