Computers & Internet Logo
D
David Korsi Posted on May 27, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I got a new computer and now I have no mic. the old one I could do a video and it would pick up my voice but none now. I've ordered a external mic but wounder why I have to.
Jay Plesset
Level 3:
  • Master 2,942 Answers
  • Posted on May 28, 2016
Jay Plesset
Master
Level 3:
Answers
2942
Questions
Helped
667514
Points
9879
It is possible that your new computer didn't come with a microphone. Or, it may be turned off, or muted, or something like that. I honestly can't tell without any information about your new computer.
2 Related Answers
Mike Matkovic
  • 125 Answers
  • Posted on May 02, 2009
SOURCE: Acer Aspire internal mic won't work.
You need to check the record settings and make sure the mic is not muted or turned down to low. Click START, CONTROL PANEL, then SOUND icon. Click the AUDIO tab up top. Make sure that your sound card is selected in the drop down menu under Sound Recording. Now click VOLUME tab. A new window will open up. Click OPTIONS then PROPERTIES. Make sure you have a check by the MIC and click OK. In the Recording Control window, turn the level up for Microphone and make sure it is not muted. Let me know what happens.
Anonymous
  • 255 Answers
  • Posted on Jun 20, 2009
SOURCE: Compaq C773:Internal Mic very low voice,External Mic not detecte
1. click on the start button on the windows screen
2. program, then accessories, then Entertainment, then volume controller
3. select option,then properties
4. select mic check box to activate your mix option in the volume controller then ok
5. you can increase your mike volume and you can put it on mute option etc..
try this, hope this will help you out.
External microphone not working
Software like Audacity (free) will usually have settings allowing you to switch settings . Your mic is likely coming through the "line in" option. That may also apply to settings you can get to by clicking the mic icon in the lowest part of your display.
Hi, I recently reformatted my hard drive and installed Windows 7. Before that, I had windows vista and my mic worked fine. Now, windows 7 picks up the mic and says it's enabled and it's not muted,...
Check the web-site of the manufacturer of the computer (and the motherboard) to see if they have updated device-drivers for Windows 7.
Are you sure that you've plugged the microphone into the 'pink' ("microphone-in") socket?
Open the "sound-mixer" application, and check that the "microphone-in" is not muted,
and that the slider is pushed to the maximum level.
Try a different microphone.
1helpful
I have an HP Pavillion dv2700 laptop with windows Vista. My mic was working fin until a few weeks ago, now no one can hear me on google voice or skype. I checked the mic settings and it is not muted and...
You can try going into device manager and find the device and remove it then reboot and let it reinstall the mic drivers. If that does not work try going to the HP site and see if a new driver is available and install it. The mic could have gone bad and you may have to buy an external mic.
Thanks for using FixYa
My mircophone is broken? dont have money to fix? any cheap ways to still use
WOW this is an expensive camera, I would first HIGHLY recomend spending the money and send it to a good electronics or camera shop and have them fix it.
If this is not an option here are a couple or things you can do. Since this is a higher end camera it
should have a mic jack, if so just hook in a good microphone and it should work fine.
A couple of words of warning before tying the next solution you could permanetly mess up your
cameras sound. While this method theoretically possible, some companies intentionally make this
very hard. Often companies will use hair thin wires or wires that are so short thier is no way to
patch into them. Also, since this description doesn't use standard hardware you should disclose
this repair to anyone who might wish to buy the equipment if you decide to sell it. Also, the mic
that I've suggested may not be as good of quality as the original Sony. You can use
any mic of about the same size so long as it has wires to tie into.
If your not real familiar with electronics get a buddy with some experience repairing electronics to help.
If your really adventurous, you could take the mic assembly apart and put in a new mic. Just get a good compact mic like a KOSS M5 and splice off the end then shave the wires. Then carefully
take the mic assembly on you camera apart look for a small disk made of two magnets an a
fillament with 2 wires disconect the wires from the disk and hook them up to the shaved wires
from the KOSS microphone (one wire from a lead the other to the ground of the KOSS microphone). The KOSS mic will have 3 wires two sources/leads and a ground you might have to play around with it to figure out the wires and get it working properly. If your mic assembly has 2 mics figure out which wires are the lead by hooking them up one at a time (to the wires that originally were hooked to the internal microphones) with the ground on the other wire and trying them. Once you figure out which are the lead wires hook them each up to the old mic wires and take the other side and hook them both up to the ground. once you have it all wired back up and any splices insulated (elecrical tape should be fine) you should be able to re assemble the mic with the new microphones installed.
If the mics for the camea are intergrated into a circuit board the same method will work but
the old mics will need to be desoldered and the leads from the new mic will need to be soldered
where the old mics were. If this is the case get a buddy with some experience with electronics to help you.
Method three use an external recorder. For this method just record the sound with another external
device like a digital voice recorder then use an editing program like Sony Vegas to add the sound to your video. The hard part is syncronization. A clicker may help create sound tags to align the video with the audio with the sound.
2answers
Mic Echoes
Echo is caused by a number of variables. Are you in a large room with mic extended away from you? Mic too far away will create echo. Also try turning down the gain for the mic
Mic not picking up voice tried 2 different mics
disturbing punctuation-oqy5fah40apqzze5k2tsaxfy-1-0_0.jpg Just buy a Microsoft authorized headset and be done with it.
Regarding the canon hv20 camcorder. When using an external canon MIC a) How do you know the mic is working and you are not picking up sound on the internal MIC b)On connecting the external MIC an icon...
If you put the camcorder in manual mode, there is a microphone sensor that will move when sound is picked up by the external microphone. In manual you can keep everything else automatic. The off for the mic means that the built in mic is turned off when an external mic is attached.
Headphones with mic / external speakers
Does your computer have front audio ports? If so, you can just plug it in there. Otherwise you need a single male 2 dual female converter to plug into the speaker port.
1helpful
Nokia 6255i (or 6256i) Verizon
check the tracks of mic to headphone
Dec 20, 2007 • Nokia 6255i
Sound problems
Hi mack79, I would assume that you are using Yahoo Messenger on a Windows machine. By "I've done the mic set-up ...works fine there", again I would assume that you have tried the YM Call Setup Assistant and you have a green light on that. By "...connected ...doesn't...pick... voices.", perhaps you simply have to activate handsfree. If my basis for assumptions are off, pls post back with details: 1. laptop or desktop; 2. are you using an external keyboard with Audio in/out; 3. is the Logitech built-in mic the only mic attached to your PC; and 4. are you using headset or external speakers? Good luck and kind regards.
Grand Canyon Tech
Grand Canyon Tech
