Problem is aux & tunner is not working.model sa vk70d
Posted by Jitu Hossain on
I have a Panasonic SA-AK 67 Can any one tell how to connect it to my phone using aux cable
Hello Zubair, to connect your phone to the SA-AK 67, you need a cable that has two RCA connectors (White and Red) to a 3.5mm stereo jack
The RCA connectors, you connect them in the AUX input that is on the rear panel of the SA-AK67 and the 3.5mm stereo jack, in the headphone output of your phone
You select Aux on the Panasonic, you play something on your cell phone and you're done
I hope you find the information useful
Greetings Franco Dosil
Hola Zubair, para conectar tu tel?fono al SA-AK 67, necesitas un cable que tenga dos conectores RCA (Blanco y Rojo) a una ficha 3,5mm est?reo
Los conectores RCA, los conectas en la entrada AUX que esta en el panel trasero del SA-AK67 y el conector 3,5mm est?reo, en la salida de auriculares de tu tel?fono
Seleccionas Aux en el Panasonic, reproduces algo en el celular y listo
Espero te sea util la informacion
Saludos Franco Dosil
http://www.usersmanualguide.com/panasonic/cd_stereo_system/sa-ak57 http://www.usersmanualguide.com/panasonic/cd_stereo_system/sa-ak77
Hi I am having problems with my Panasonic SA-AK200 stereo system when in AUX mode. What happens is when I play through AUX mode The Sound only comes through One speaker usually the right one but when on cd...
Looking at your question, it appears that the problem is not always on the same channel (right/left). This makes me wonder if the problem is the source or the cables you are using. The easy way to test this is to connect everything, check which speaker is not working, then swap the left and right cables at the aux jack. If the same speaker does not work, then it is a problem with the SA-AK200. If the problem switches to the other speaker, the SA-AK200 is not the problem and you should try replacing the cables or suspect the source (whatever you are trying to connect to aux) is at fault. If the SA-AK200 is the problem, I would suspect bad solder connections at the input jacks. Good luck
Panasonic model no sa ak 67 aux not work please makenic in bokaro
my set model SA-AK67
its cd mechanism motor is not working.supply ic coming from main pcb to cd loader ocb.please advice
1helpful
Hi is it possible to connect a laptop to a denon 700aedab for music playback
HI, very possible. Just follow this instruction:
All yo need to use for the connection is to get an RCA TO STEREO JACK HEAD (use the google image to see the type of cable).. Connect to denon 700aedab, make sure that the denon 700aedab is on either aux, tunner,video,etc. Those auxillary options on your denon 700aedab.
Connect the RCA into the aux of the denon 700aedab and connect the small jack head into the laptop ( where you plug in earphones),and play and enjoy your music.
If it does not play with aux try tunner, or video, one mustplay,and if it does ot play any, that means either the port of your laptop or the denon 700aedab port is faulty.
And don't forget to connect the speaker,because diffidently you will sure hear absolutely nothing with out the speaker.
Feel free to pass your comment .
Thanks for using fixya.
My SA-VK70D got F61 and imediatelly turn off..:(
i have vk70d and i have same problem .....your cooling fan not working ...chand it ...its work ....
2answers
Remote control
Which universal remote do you have? Any of the Harmony remotes should be able to control the panasonic.
Connecting ipod
Yes you can connect your i-pod to your sa-ht 930. You can buy a connection at Walmart for $5 bucks or you can go to Tareget and buy a monster connection for about $25 bucks. I bought the monster connection and works great. All you have to do is connect it to the AUX in the back to the white and red jack in put. Once you connect it change the input selector to AUX and you're ready to go.
Open Questions:
 Grubhead
Grubhead
Marvin
Marvin
