My laptop slows down and gets stuck whenever i play some files like movies on the windows media player. i have run full computer scan several times but no error regarding the slow response is detected and all OK message is displayed. but the problem still persists. please help me.
Reason 1. The Windows Media Player may not work with some certain video files.
For example, some people would like to watch DVDs on Windows Media Player.
Reason 2. The Windows Media Player is not completely supported by Windows 10.
After the Windows 10 was released, some news you might have heard about is that Microsoft decided not to support the Windows Media Player.
Reason 3. The Windows Media Player could be just freezing .
This reason can be tricky because every system is likely to meet some freezing issue moments.
Reason 4. Probably you can only run this program as an administrator.
With nothing running, I would click on Start ' Run ' Type CMD to get to a Command Prompt.
From the Command Prompt, type sfc /scannow
This will run the Windows Resource Checker Version 6.0 program and it will verify All Windows files on your system are correct and not corrupted. At the end of the scan, if you get a message that indicates it could Not fix the problem, re-run the above command again.
The Other option is to download a program called MediaInfo. Once you install this program, it will allow you to right-click a Media File (.mpg, avi, mov, etc) and check to see details about the media file. You can download this Free program from address: https://mediaarea.net/en/MediaInfo
Another More useful program is something called the Sherlock Codec Detective. This Free program will tell you if your system has all of the required Codecs to play the file you are trying. You can download this Free program from address:
http://www.updatexp.com/sherlock-codec-detective.html
The File is located here:
http://s3.amazonaws.com/sherlock/sherlock.exe
So, after you install MediaInfo and see what the file contains in terms of Codecs, you use the Sherlock program to see if your system is missing any files that are required to play this. Anything missing will typically be shown in Reg under the column Video Codecs Installed (within Sherlock)
The "other" option is to download a Free program called the Media Player Codec Pack found at this address:
https://www.mediaplayercodecpack.com/
I would install either the Lite or Standard edition of the Codecs. I know some users will say Stay Away from Codecs, but since I found this Free program years ago, I can smoothly play DVD movies on my system. Please be aware that you should Backup your System before installing this Codec pack as it May over right a paid for Codec you might already have currently on your system.
This software is compatible with:
Microsoft Windows 10, 8.1, 8, 7, Vista, XP, 2000, 2008, & 2003
Microsoft Windows Media Player 12, 11 & 10
Any player compatible with DirectShow
The Last option I have is to make sure your Windows 7 system is up to date with installs. Do a manual check for updates and look under
the Optional Updates. If I remember correctly there was several patches/fixes from Microsoft to fix issues with the Media Player as well.
Best of Luck!
SOURCE: Installing Office 2007 Enterprise on new Systemax PC
Once installed, was unable to re-boot the system.
The system kept cycling between logging on and logging off.
Prior to installation, my PC had no problems. All the diagnostics were performed.
The system had MS Office 2003 suite already installed and I had hoped for a seamless update!
Perhaps my naivite got in the way!
Thanks!
SOURCE: Problem installing office 2007.
You need to uninstall any pre-release version of the Microsoft Office 2007 system .
it seems that if you have a version of the 2007 Microsoft Office Add-in
or Microsoft Save as PDF or XPS installed, this may be the culprit. In
both cases, by performing an uninstall on this add-in via the Control
Panel, and then installing Expression Web, everything works okay. You
can even re-install the Office 2007 add-in when you're done.
Goodluck,
Please don't forget to rate the solution
SOURCE: not able to access MS office
http://support.microsoft.com/kb/933347
Here is what you need. Just click the Link Above. Please Rate My Response! Thanks!
PREM
SOURCE: Office 2007: Windows Installer searches for Office 2000
It looks like a problem with file associations. The computer maintains a list of file extensions and the programs that will open files with such extensions.
Please go to the link below for details on changing file associations:
http://support.microsoft.com/kb/307859
SOURCE: MS Word runing VERY slow on Windows 7
Spyware is computer software that spies on your internet usage. It collects highly personal and confidential information like credit card numbers, IPs and even addresses. The spyware program gets the credit card entries as the user logs them on a web form or an online application. Some spyware are even programmed to record your usage of the internet, what sites you visit, what files you download and how long you stay online.
