Question about Sony KP-65WS500 65" Rear Projection Television
Do this TV come appart for easy transportation
I've just received my new bush 49inc TV and on one corner of my LCD screen is loose and a bit floppy the other three corners are securely tight is this normal..
Can be a manufacturing defect or transportation problems If its easy to replace the TV then try for it. If not you can continue to use it.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 31, 2017 | Bush Televison & Video
Won't stay closed
check the seales on the sides of the unit or take appart the latch asemberly very easy may need replacing
May 27, 2014 | Bosch SHE3AR55UC Builtin Dishwasher
Changed boot sequence in bios, now I cant access bios, and screen is blank. is there an easy way to reset the laptop back to factory?
The only way to reset the BIOS is to take the laptop appart, remove the CMOS battery and short the reset jumper on the motherboard. Unfortunately this is unrealistic unless you are handy with taking things appart and putting them back together.
Let me know if you have any questions.
Jun 29, 2011 | Averatec AV1050-EB1 PC Notebook
Dvd is stuck in insignia 32inch tv/dvd combo. how can i eject the dvd?
Look at the side where the dvd player to see if it has a small pin hole for inserting a paper clip to eject the disk, if it does not have one then the TV and the DVD transport will have to be disassmbled to get the DVD out. It will not be an easy job so you may want to leave it to the pro to do it.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Sep 28, 2010 | Insignia 32" 720p Flat-Panel LCD HDTV
Moving the TV
TV should be in upright position during transportation in some safe packing around it.
Thanks.
May 13, 2010 | Toshiba 50H82 50" Rear Projection...
I have a pontiac sunfire 2001 and the blinkers have stopped working, is this and easy fix?
sounds like your turn signal switch on your sreering colom common problem haft to take the steering colom appart to fix
Mar 13, 2010 | 2001 Pontiac Sunfire
DVD player not working, only used a few times AKAI lct32z4adp 32"lcd tv with built-in dvd player
Unfortunately they are a real bare to fix. Unless its a jammed disc it is probably a defective transport. If it is under warranty have it repaired otherwise get an external DVD player.
Sorry I don't know of any easy fix for the integrated units.
Cheers
Jan 06, 2010 | Akai CFTD2085V 20" TV/VCR/DVD
Panasonic PT-51G44 51 transporting?
No you should only transport it standing up to ensure the optics do not get messed up. I have seen peeps do this and nothing happens. I have also seen pros do the move on the back or the sides and it tears up the TV set. Good Luck
Aug 30, 2007 | Panasonic PT-51G44 51" Rear Projection...
Sony KP-65WS500 65" Rear Projection Television Logo
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
