Question about Kenmore Washing Machines
When I was fixing the door switch for my Kenmore front load washer this spring fell out. Where does it go?
Posted by Marjorie Swehla on
John Flurry
    Scholar:
    New Friend:
  • 70 Answers
I've seen that door lock assemble before and I normally just replace it. But good job on your end to give it a go. That door lock has a coil that when energized it closes on the door strike. When its de-energized, that springs assist to open the lock. I can say exactly where it fits, but look for a spot between the red part on inside. Good Luck
Posted on May 25, 2016
5 Related Answers
Anonymous
SOURCE: Kenmore top load washer counter balance spring
There's a nice picture here.
Posted on Feb 20, 2009
Anonymous
SOURCE: kenmore front load he3 washer: door wont unlock
happened to me once - I just unplugged the machine - waited a minute and plugged it back - it - then used cancel button
Posted on Mar 02, 2009
Anonymous
SOURCE: torn door seal on front loading washer
My husband used super glue on the tear and for now the washer is not leaking.
Posted on Mar 26, 2009
Anonymous
  • 382 Answers
SOURCE: kenmore (HE2PLUS) front-loading washer leaking out
check the inner door seal it may be damaged that may be why it is leaking
Posted on Dec 17, 2009
Anonymous
  • 92 Answers
SOURCE: Kenmore HE2T Front Loading Washer Leaks From Door
there is a dispenser hose that goes in the tub.alot of times a sock or something gets inside that hose.that would cause your trouble.take the boot off the front and look up and left to see that hose.it comes out of the tub pretty easy.
Posted on Feb 04, 2010
My kenmore front load washer doesn't want to start all lights are working but nothing happens even the door won't lock
your door switch is the problem,where the door latch goes into the machine a little switch sites behind this a safety feature and if this is broke the machine will still switch on but will not work it will need replaced they are cheap.adrianxxx
Jun 02, 2012 | Kenmore 44072 Front Load Washer
One of the fins on my Kenmore front loading washer fell off
The entire agitator must be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 06, 2009 | Kenmore Washing Machines
Door won't lock shut
Removing the door safety switch:
1. Disconnect the washer from the electrical supply.
2. Release the bellows from the front panel:
Releasing the bellows (door boot) from the front panel:
The front of the bellows is installed over the lip of the door opening in the front panel and held in place by a spring loaded wire loop.
3. Open the loading door.
4. Using needle nose pliers, start where the spring and wire are connected at the bottom of the bellows and pull the wire out of the groove of the bellows.
5. Pull the bellows off of the lip of the front panel.
6. Remove the (2) screw holding the switch assembly to the front panel.
7. Pull the switch assembly into the door opening and unplug the electrical connectors.
Install is the reverse of removal.
Jul 30, 2009 | Kenmore Washing Machines
Kenmore elite lock problen
I had the same problem. Turned out, electronic panel behind the door had spring action malfunctioned because of misplaced spring, which in turn caused panel to not generate a signal which, stopped the whole cycle.
Here is what I did to fix the problem- 1. Open the door 2. Remove the ring behind rubber-cover on the door. 3. Reach out to the inside-right of the door. 4. Remove the panel after removing electric connections. 5. Fix the spring action. 6. Put everything back and start the machine over.
Dec 31, 2008 | Kenmore Elite 45986 Front Load Washer
Front Loading washer Kenmore Ht3
Here are the steps to unlocking the door manually if clothes are still in the machine.
1.Unplug machine
2.remove bottom panel
3.Reach up along the inside of the front panel and locate the botttom of the door latch assembly
4.Located on the bottom of the door latch assembly is a tear dropped shaped tab
5. Gently pull down on the tab about a 1/4 inch or until a click is heard.
6. You may now open the door.
This code means the door lock mechanism has failed or the central control unit has failed. Replace the door lock mech. first. This should fix the problem. (before replacing anything make sure there is no obstruction around the switch or in the switch.) After the machine has been unplugged it may fix itself. if not replace door lock mech.
Nov 15, 2008 | Kenmore 46462 Front Load Washer
Kenmore 3.5 Super Capacity #4810 front load washer
easy fix bellows is held on by spring around outer edge remove it roll bellows back 2 screws in lock assembly pull toward opening remove wires spring may require a little patience to reinstall but no big deal did 2 today..be sure to ck door strike also ..the little plastic piece on door frame that goes into lock
Jul 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 417.29042992 front loader washer
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 23, 2008 | Kenmore 44102 Front Load Washer
Metal ring aroound rubber seal fell off.
Start with the spring at the bottom, work the retainer around until the seal starts to pull away from the washer. Now grip the loop that the spring attaches to on the side that isn't in place and open the retainer. Push the retainer in place and release the spring.
Jan 09, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
42 people viewed this question
Michael Thomas
Michael Thomas
Lawrence Oravetz
Vernon Taylor
