Question about NorStar M7310 Corded Phone
How do I reset the prime line on my Norstar M7310? It defaults to line 2 when I pick it up and I want it to default to line 1.
Posted by Marci Jones on
5 Related Answers
mark hudson
  • 326 Answers
SOURCE: Call Customer Service 1-8O5-465-751O To Fix Issue Norstar M7310 corded telephone
  1. Press feature
  2. Type **266344
  3. On password type 266344 (wont show the numbers as you putting them in)
  4. Terminal + extns will appear, press line 6
  5. Find ext number, type number and the name will show up
  6. Press line 6, line access will appear
  7. Press line 7 twice and change will appear
  8. Enter the name then press line 1
End session and save
worked for me, hope it helps
Posted on May 05, 2008
Anonymous
SOURCE: reset Norstar M7310 System Administration password
This works, i just did it today!!
Press Feature 985
Press the 9 Key
Enter RESETSMPSWD (73738767793) using the dialpad
Press YES
Once you have RESET the password, it reverts to the default.
See Below
If your system uses 2 digit extensions use 120000
If your system uses 3 digit extensions use 1020000
If your system uses 4 digit extensions use 10020000
Posted on Jul 03, 2008
ynotphone
ynotphone
  • 192 Answers
SOURCE: how can i change my extension nuber (norstar M7310)
Sorry can you clairify this question...
-> You need a new extension number for your set?
-> You need a new extension on your set so you can see when they are on their phone?
If it is the first, there are many things that you need first, too much to explain at the moment. But you need to have the password and a template for your phone to make changes.
If it is the second, press:
- Feature * 0 and any button to find out what is on the button, look for an empty button or one that you want to overwrite,
- then RLS,
- press FEATURE * 2
- press the button where you want to add this new extension
- dial the extension of the new person
Voila you are done!
Posted on Jun 03, 2009
consultel1
george peters
  • 860 Answers
SOURCE: Our Automated Attendant for our Norstar M7310 is
assigning messages is done by
feature 983>1020000>AA>Table>table 1>Greeting Type
depending on how you have the business hours times set it'll play the greeting you want. Typically I set the greeting type as morning:1, afternoon:1, Evening:1 and Non-business:4. then under business hours I set them up as mon- fri morn:0800am, aft:0800am, eve:0800am and nonb: 0500pm. sat and sun as morn:1200am, aft: 1200am, eve:1200am, and nonb: 1159am
press Rls when finished
that way when a caller calls between 8am and 4:59pm they get the day greeting and from 5pm to 7:59am they get the night greeting (greeting 4) saturday and sunday play the night greeting all day.
Dont forget to record greeting 4 as your night greeting.
Posted on Oct 14, 2009
mycomputergu
SOURCE: Norstar m7310 needs rls button pushed after every call
I've seen this many times; Check the Handset cable. It is probably plugged into the Headset connection on the phone.
Posted on Jan 04, 2010
How do you reset the phone system... it sound like a rotary dial when Im calling out
If it's rotary then your system was reset already.
When a system defaults it will assign 2 lines to all phones and give Jan 1 as the date.
Change from Rotary to Touch tone is done under Config/Lines/Data
If unsure who to program or navigate or config password then call in a vendor/tech.
Sep 24, 2012 | NorStar Meridian M7310 Phone
I can not access my main line
If a system defaults programming it assigns only lines 1 and 2 to each set.
You either had this issue or somebody removed line 3.
Call a tech in to program.
Aug 01, 2012 | NorStar Meridian M7310 Phone
We have lost power a couple times this week and our system had reset, losing our third line and voicemail greeting will not prompt when suppose to. We still have out greeting, it is just not picking up.
What type of System is it? Norstar systems default to 2 lines if they loose memory (which isn't supposed to happen). That being said, I recently had had to replace an old Norstar 616 that would not hold memory after a power outage. I took the KSU apart and could not find any internal battery to replace. I'm guessing some kind of capacitor ?? In any case the system had to be replaced. Bill C. www.dyna-tech.us We also do remote programming on Norstar CICS ans MICS.
Mar 26, 2010 | NorStar M7310 Corded Phone
My Norstar M7310 System Admin Password
to reset the administrator pasword enter feature 985 press 9, at the password prompt enter 73738767793 (resetsmpwsd) and press ok or #,press yes to reset password. password should be defaulted to 0000. then try Feature 983. if your system has 2 digit intercom #s your password is 120000.
Feb 11, 2010 | NorStar M7310 Corded Phone
Mailbox locked how to unlock it
First you will have to find out the extension number that is giving you issues.
How to Change a Mailbox Password
1. To access the voice mail system press "Feature".
2. Press "983".
3. When you see "Log:" enter "120000" for 2 digit extension numbers, enter "1020000" for 3 digit extension numbers.
4. Press "OK".
5. Press "MBOX".
6. Press "CHNG".
7. Enter the mailbox number you wish to reset.
8. Press "Reset".
9. Press "Rls" to exit (orange button to the right of the number buttons).
Default password is "0000".
Apr 20, 2009 | NorStar M7310 Phone
How do I change the default line on our phones
restore the factory settings of your mobile byentering the security code of mobile.
Feb 04, 2009 | NorStar M7310 Corded Phone
M7310 phone buttons
Wow, you should get 2 lines and at least one intercom by default. Lines are assigned in most Nortel systems in Terminals & Sets. Your COPY command is your friend. Just pick a phone you wnat to emulate and copy it to your new set.
Carl
Sep 01, 2008 | NorStar M7310 Corded Phone
Answering call
Feature ** 266344 password 266344 (assuming the default passwords are set)
A. Configuration
2. Line Access
Show set (enter the telephone extension set number that needs to be changed) ex 34
Then press enter 4 times until you see the 'Prime Line'
Press the change button to set the desired line that will activate when the handset is picked up.
(It will probably display 'None' at present before change)
Press enter and release.
Aug 19, 2008 | NorStar M7310 Corded Phone
Norstar ICS 4.0 password
How to Change a Mailbox Password 1. To access the voice mail system press "Feature".
2. Press "983".
4. Press "OK".
5. Press "MBOX".
6. Press "CHNG".
8. Press "Reset".
Jun 20, 2008 | NorStar Meridian M7310 Phone
NorStar M7310 Corded Phone Logo
323 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
pbxinc
martin hogg
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
