Question about Hoover Washing Machines
Hoover 500Mb Heavy Duty washing machine,it is extremely loud on spin cycle, works fine but very very loud on spin cycle? Does anyone know what is causing it? Thanks
Posted by Simone Parker on
Nater13
    Master:
  • Hoover Master
  • 610 Answers
The main seal has allowed water into the spin bearings...
Posted on May 25, 2016
  • Simone Parker
    Simone Parker May 25, 2016
    Thank you Nater 13 for your advice and very quick response, much appreciated
My Hoover 500Mb is extremely loud on spin cycles, it works great but very loud just on spin?
as you have probably found out by now the drum bearings are worn out probable due to the seals leaking ,new set of bearings and seals if not already fitted.
May 25, 2016 | Hoover Washing Machines
Hoover 500mb washing machine doesn't 'click' through the cycles
Sounds like your timer is not working correctly. I would suggest replacing it, as there isn't a way to repurchase timers.
Oct 10, 2015 | Hoover Washing Machines
Hoover 500mb washing machine failing to spin.
my does everything but it just wont spin drye
Mar 25, 2012 | Hoover HTC243 Top Load Washer
Hoover 700LB Stops at the wash during the wash cycle keeps clicking then starts again at the spin cycle
It sounds like the timer is bad. Try another cycle like delicate, or normal, or heavy duty. If everything works on another cycle then it is probably your timer. If it doesn't work and you have the same problem, then it is probably an expensive fix. Best of luck
Mar 21, 2010 | Hoover HTC243 Top Load Washer
We have a Hoover select 1500 washing machine. It still washes and rinses ok, but doesn't then move onto the spin cycle. But I can manually set the dial to spin and restart it. It then spins fine. I assume...
Could be but also could be rinse water valve not operating due to faulty solonoid. it does a final rinse / softner before spinning if valve faulty then no spin advance....
Nov 11, 2009 | Washing Machines
Kenmore 90 series with speed selector switch set to heavy duty cycle it works fine any other setting , regular , hand wash setting the agitator makes a loud clicking sound as it agitates
sounds like a transmition problem. does the noise happen when it goes into spin on the other settings? If no noise in the spin cycle on the other setting, then it sounds like a the gears in the transmition internally when bad for the agitation.
Jul 30, 2009 | Kenmore 15864/15862 Top Load Washer
HOOVER 500MB WASHING MACHINE
the pump hose has to be above tub level or the water will run out
the dial control unit is faulty and if the parts are are available will cost up to $150.00 aud approx to buy
the leak under the machine could be from a tub to pump hose or water level hose up to sensor
how new is almost new as it seems you have inherited a lemon and not a working machine
Jul 17, 2017 | Washing Machines
Hoover 800 heavy duty washing machine
the clicking sound could be the brake arm worn its white and in the middle near the gear box,the reset is for water only.the outlet pump is at the back where the drain hose comes out.the filter is in the middle of the agitator just pull it out.check the belt isnt loose.
Jan 02, 2008 | Hoover HTC243 Top Load Washer
Washing Machines Logo
100 people viewed this question
Top Hoover Washing Machines Experts
peter gittos
peter gittos
Poppa Maddo
Poppa Maddo
Steve F
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
