2000 Ford Contour Logo
A
Anonymous Posted on May 25, 2016
Why wont vehicle turn over
Battery charged, starter is new and ignition switch good.
Jeff Armer
Level 3:
  • Ford Master 15,575 Answers
  • Posted on May 25, 2016
Jeff Armer
Ford Master
Level 3:
Answers
15575
Questions
Helped
7100677
Points
73899
Is the anti-theft light lit ? Is the starter relay good ? Do you know what a relay is ? Are the battery cables good ? I would start will the starter relay circuit's if the anti-theft light is not lit.! The starter relay along with the starter relay diode is located in the battery junction box in the engine compartment. The relay is K-22 . If you pull out the relay an look on the bottom of the relay you should see four sets of numbers 30,87 an 85 ,86 . If you take a jumper wire (12-14 gage ) an jump pins 30 an 87 if the battery cables & connections are good the starter will crank . Pin's 85 &86 are the control side of the relay . One of these comes from the ignition switch when is start position an the other goes through the transmission range sensor (park neutral switch) To ground or the PCM if yours has a V-8 . Now if when you jump pins 30 & 87 an nothing happens you have bad connections or the battery cable is bad . You can go on youtube an check out videos on voltage drop testing the starter circuit .
Why wont vehicle start?
There are many, many reasons why a car wont start and it is very difficult to give you advice because of this. You are better to have it transported to a local car repairer and they will be able to work out what is wrong.
2answers
1991Buick Riviera wont start has dash light but starter won't kick over unless you jump the solenoid
check for power from the ignition switch to the solenoid. probably turned off by the immobiliser
1helpful
Car wont crank over fron ignition andit cranks over when jumping the starter but still wont start
Could be your ignition switch itself not relaying to coil. I dont know vehicle specifics but there should be a wire from coil to dash, on fords it is red and baby blue if I remember right. Check this it may be grounding itself out.
1helpful
4answers
2003 trailblazer has new battery, but will not crank but all dash lights come on
Check the starter, check the cable that goes from the battery to the starter. make sure its tight and not loose. take a hammer and tap on the starter. If the vehicle still doesn't start. Change the starter.
3answers
My eagle vision wont start turn switch i have nothing battery is good starter is good
Hello , i believe your vehicle alternator is charging less than usual 11,5 volt instead of 13.5 v ,, check your vehicle alternator readiing
3answers
I own a 1990 sportster 883, when i try to start it, the lights dim and the starter clicks but wont turn over. Battery was at 11.65 volts. I did a continuity check on stator and ignition coil. All was...
Your starter and or solenoid is bad. Get a new starter. And new solenoid if it is seperate from starter. Sounds like starter is causing a short. Had that happen to a few bimes and vehicles i have owned
I’m happy to assist further over the phone at https://www.6ya.com/expert/chris_ec38c09da1ae48dd
1helpful
2answers
Engine will not crank, makes cliking noise when turning ignition switch
either the battery is dead or your starter, try jump starting the vehicle. if it is not the battery then have someone tap on the starter while the ignition switch is turned. Hope this helped Tim
3helpful
2answers
My 2000 oldsmobile intrigue is not starting no power to stater is a 3.5
CHECK BATTERY VOLTAGE IT SHOULD BE 12.5 VOLTS.IF NOT BATTERY WEAK NEED CHARGING OR REPLACED.IF BATTERY GOOD.TURN IGNITION SWITCH TO ON POSITION WITH ENGINE OFF.DASH LIGHTS SHOULD LIGHT UP IF NOT.CHECK IGNITION SWITCH FUSE.IF FUSE GOOD YOU HAVE A BAD IGNITION SWITCH.IF SWITCH IS GOOD.I AM LOOKING IN FAULT IN STARTER SOLENOID OR STARTER.OR BATTERY CABLES NEED REPLACING.WARNING TURN OFF RADIO BEFORE DISCONNECTING NEGATIVE BATTERY CABLE SO YOU WONT LOSE RADIO PLAYING CODE.
3helpful
3answers
My type 2 bay 1978 camper wont start! when i turn the key i get a click and it wont start how can i fix this?
Battery is good & charged ??
Starter could be stuck if it has been sitting a long time..
While turning the key - smack the starter (not too hard) with a small hammer or hevy wrench..
Seems battery being drained
Q1. Engine will not start or is hard to start (Cranks OK) A1 -Ignition lock switch faulty -Ignition coil faulty -Power transistor faulty -Spark plugs faulty -Ignition wiring disconnected or broken -Spark plugs faulty Q2, Engine will not crank A2. Battery discharged Battery cables loose, corroded or worn out Transaxle range switch faulty (Vehicle with automatic transaxle only) Fusible link blown Starter motor faulty Ignition switch faulty Ignition lock switch faulty REMEDY Charge or replace battery Repair or replace cables Adjust or replace switch Replace fusible link Repair starter motor Replace ignition switch Replace ignition lock switch
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
