SOURCE: How do I view Sent messages on my IPhone 4 - Sent items isn't an option
for sending text messages :
1.go to your message settings and check the message center number to see if it is correct
2. call to your network operator customer care
3. request the message center number...
4.note it down
5. go to message settings>message center number
6. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
SOURCE: How do I delete an email address entered wrongly on IPhone 5c
Click "edit" on the upper right hand corner and then the minus (-) sign that appears next to the address to be deleted. Then click "done".
You do not receive alerts when your phone is all the way off. But if it is just on Standby, you should. Try checking if your Airplane Mode is on.
SOURCE: my husband receives the texts meant for my iphone
Try either googling it or you tubing with the same query and the phones information and you should be able to solve the problem . Did he give you his old iPhone 5 if so it could still be in his name as the first owner . Hope this helps but try googling or you tube .
