Question about MTX Car Audio & Video
Install/user guide for MTX THUNDER 564 4 channel
Does any body have a user guide or manual for a MTX THUNDER 564, and its a 4 channel amp
Posted by gary hurlocker on
4 Related Answers
Cerfer39
Greg Stokes
  • 709 Answers
SOURCE: confused
Hi jimmyjames,
How do you have the wires hooked from the sony reciever to the inputs on the mtx?
 Sounds like your Remote wire is way too big. it should be 14 guage.  It only sends a low voltage low amp signal.
Another thing that could be messing up the sounds is the routing of the wires.  you should have the power supply wires separate from the Audiop signal wiring.  Power should run down the Driver side and Audio down the passenger side.
When you answer I may be able to tell you more.
Posted on Oct 19, 2007
Anonymous
SOURCE: directed 1100d 2-channel amp
well the 1100d directed amp is a mono block.... but yes tou would run them in series which is pos 2 neg on each speaker if there 4 ohm and if there 8ohm run it parrel pos 2 pos neg 2 neg....
Posted on Dec 17, 2008
Anonymous
SOURCE: MTX Thunder 81001 wont push subs
first of all you should check the minimal impedance your amp handles , if is class d it should handle between 1-2 ohms total impedance in a mono conection , meaning whatever quantity of subs you have hooked to your amplifier,their total impedance should the minimum the amp handles that way all the power from your amplifier will be used.
Posted on Jan 23, 2010
gopakumarg43
  • 76416 Answers
SOURCE: need manual for mtx audio thunder 4501
Hello
Get into this link. You can download the user manual to your device from here. OK.
caraudio.manualsonline.com/manuals/.../mtx_audio/mtx_audio_car_s
Posted on Jan 14, 2012
How do I Bridge MTX Thunder 404 400 watts into one channel
The mtx thunder is a 4 channel amp. 4 channels can't be bridged to 1 speaker. You can only use one side of that amp to bridge your speaker. Unfortunately your now only using half your amp.
Nov 25, 2016 | MTX Car Audio & Video
Need manual for mtx audio thunder 4501
Hello
Jan 13, 2012 | Car Audio & Video
I have a mtx audio thunder 4202 amp is it just meant to use for sub woofer or can it be used for front speakers as well ? is it 2 or 4 channel and what does that men?
yes, the amp can be used fof full range speakers. to use it a s such, the amp's "crossover" switch must be set to "off" (could also be labeled as "full-range" or "defeat").
the amp is 2 channel. 4 channel is for surround sound or to have independent front and rear channels/volumes. this 2 channel amp will support 4 speakers, but you wont be able to balance from front to back- the front and back speakers will be at the same volume all the time if both are hooked up to the amp.
Mar 12, 2011 | MTX Car Audio & Video
What kind of amp should i get for my kenwood mids and highs
you should go for a 4 channel amp that has 500 watts and try to go for MTX
Aug 04, 2010 | MTX Thunder 4250D Car Audio Amplifier
2 MTX Thunder Problem.. Bridging?
Is there a option on the chanels that say ''Bridged''? If so, you can hook the subs up in parellel or series to get different ohm loads. Usually the lower ohms, the more power amp puts out. Those subs can handle 225 watts RMS whitch means the power it can handle constantly. If the amp gives more than 225 watts RMs, you could be at risk of blowing the sub. If you could give me the model # of the amp, I can be of more help.
Feb 11, 2010 | MTX Thunder 4500 T4510-04 Car Subwoofer
I have a mtx thunder 81000d amp i need to know if i can bridge it
Hello frank_sadach,
"Bridging" connects 2 amp channels to one output. The MTX 81000d is a single channel amp so it cannot be bridged.
Hope this helps.
Oct 23, 2009 | Car Audio & Video
Setting for...
HI DUDE .. U CAN ONLY SINGLE PC OF JL SUB BY BRIDGE MODE ... COZ UR MTX AMP HAVE 300WATTS RMS ....
Apr 05, 2009 | Alpine MRD-M301 Car Audio Amplifier
Picking the right amp.
yes you could go with a 2 channel. You could alwayse bridge it.
Jan 07, 2009 | MTX Thunder 4500 T4510-04 Car Subwoofer
Mtx blue thunder pro3002
Take this apart and look at the magnet wire windings look for any thing broke or burnt. If not it is very likely it is more cost effective to buy new.
Feb 01, 2007 | MTX Thunder 2-Channel Amplifier 502 Car...
Car Audio & Video Logo
164 people viewed this question
Top MTX Car Audio & Video Experts
Marvin
Marvin
Steve F
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
