Have a TCL L55F3300FS. Customer had moved TV with cable connected and sheared off the RF tuner. Replaced the tuner and now TV does not turn on at all.
Just wondering if there are further issues in the main board and should I replace it. Checked fuse and power in on power board. Just get no standby light and no power on at all Appreciate all your help.
Posted by Rhea deLascy-Wells on
brian williams
    Genius:
  • Televison & ... Master
  • 1,864 Answers
Take back off of tv and make sure all ribbon and connectors are seated correctly.
Posted on May 24, 2016
  • 1 more comment
  • Rhea deLascy-Wells
    Rhea deLascy-Wells May 24, 2016
    I had done all that....any other thoughts please?
  • brian williams May 25, 2016
    If it was powering on before tuner was replaced it would almost have to something not plugged in.
  • brian williams Jun 03, 2016
    If no standby light and fuse is good probably shorted when tuner broke. Time for new board
How do I connect my Sansui 6010B VCR with an analog TV and a DTV tuner?
two ways of connecting VCR with Analog TV with DTV tuner.
DTV tuner (RF) output to VCR (RF) input,VCR (RF) output to analog TV (RF) input.
turn DTV tuner on (VCR should have a TV\VCR switch that makes signal coming from tuner BYPASS VHS right into TV) note:: change channel FROM tuner.You should be able to record by placing a blank tape and pressing RECORD.
2ND. DTV tuner, VCR, should have a RCA in\out connections...Audio & video.You need a RF\RCA bypass switch. It has a INput with RCA connections to a RF signal out that goes to the RF Input of analog TV
Jun 21, 2011 | Sansui VHF6010 VHS VCR
Tip
RF Modulators and cable connections
RF MODULATOR HOOKUP
For a TV with only a RF input jack, a RF Modulator can be used to hookup DVD players, DVD recorders and other devices which output RCA composite video and audio. For example, analog cable TV can be connected using a RG-6 type coaxial cable to a VCR or older DVD recorder's analog cable ready tuner RF input. Then as shown above, the output can be connected to the TV thru the RF modulator. The modulator outputs on channel 3 or 4 for the older TV so the TV is set to channel 3 or 4. Some RF modulators are built-in to Audio/Video switch boxes. These allow multiple RCA inputs along with RF input.
RF MODULATOR CLOSE-UP
The modulator converts signals to channel 3 or 4 so older TVs can tune them on their analog tuners channel 3 or 4.
RF Modulator - buy online
http://sewelldirect.com/belkin-rf-modulator.asp
on Aug 23, 2010 | Audio Players & Recorders
How to connect tv tuner
there is a simple way to connect the tv tuner just socket is given on the panel and connect in inlet it .
please give your ratings.....Thanks to giving me chance to help
Mar 30, 2011 | Televison & Video
I have a Sanyo Tv model # SC31520 that dose not have a Cable jack on the back how do I hook it up to the Cable if it does not have a cable jack on the back
You will have to purchase cable that was once used to connect an older VCR to the TV. This cable connector will go into the RF connection of the TV to the RF connection on the cable box. If the RF connector you are looking for in the back of the TV is gone...you will have to find a TV tech to attach a new RF connection to the tuner of this TV. Hope this will help with a solution!
Feb 13, 2011 | Sanyo DS31520 31" TV
I have a General Electric Model: 27GT620 TV circa 1998; the cable connection has become loose and has caused the picture to go from picture to snow; originally we could "wiggle" the male...
Yes, you have a bad ground on your RF connector. With lots of patience, it can be repaired. You must remove the tuner shields from the TV. It will need to be unsoldered. Pull the shields off either side of the tuner. Donot even attempt to move the red coils you see in the tuner. If the red coils look bent or smashed it is for good reason. Do not bend or move these. I cannot say enough about these. Next you will solder the Rf connector and the tail that is is still connected to the tuner board. Inspect all the solder connections on the solder side of this tuner on board.There are about twenty bad grounds. You will have to really concentrate and excercise great caution to solder. Be careful not to burn any traces on the tuner board. Patience is a virtue here, any mistake may destroy your TV. After careful inspection and soldering you may resolder the tuner shields. If you feel you must replace the Rf connector that part is an RCA #215543. Remember it will take more than replacing this connector, to fix the snow you receive on the TV. Thanks for asking and show a few hands of support.
Dec 28, 2010 | GE 27GT620 TV
Cable hookup broken
Sometimes you can replace the rf connector by resoldering it with a replacement rf. You will have to remove the tuner to do this. The big question is did you crack the tuner board or the board the tuner is connected to. You will really have to examine these. In most of my cases a successful replacement rf connector will fix.
Aug 24, 2009 | Sharp 27N-S300 TV
My TV is fine...problem happen when I was moving today,not sure what its called but its the silver projection located on the back of the TV is which you connect the cable on the wall too...it broke...
Hook the cable up to the VCR or if you don't buy a RF converter from radio shack or electronics store which will have a coax connector on it with component and Svideo to send to the TV. Select the connection (Component or Svideo) in the TV menu. If you only have the coax connector on the back of the TV without any other connection, you will need to get that tuner board replaced.
Aug 18, 2008 | Televison & Video
TV Green
satellite box send out siginal in the same frequency, so the tv tuner doesnt have to work on it, but all siginal coming to the Tv goes through the turner.
Jun 25, 2008 | Televison & Video
There is some problem in tuner section
your tuner is damaged and might still be able to be repaired ,don;t pull or break the rf connector.take it in for repair,before you need a tuner replaced at a higher cost to you.
Mar 20, 2008 | Toshiba MD14H63 14" TV/DVD Combo
Tuner Problems
OK the tuner may be causing these problems, however first I would like you to go to your menu and set the RF pickup to antenna (This will allow analog channels) then come out of the memu and select a channel in the analog range channel 4, 7, or 9 try to tune in these channels. If this fails then you may have tuner problems the only way to be sure is to use a RF signal generator to send RF through the tuner and see if the video and audio being carried on that signal comes through. Sometimes the Internet connect gets messed up when the TV does not have the proper RF filters this may be your case. Try this use a Cable tv set top box and just set your TV to channel 3 for cable. This should Isolate the TV from the Internet cable modem and provide the signal needed by the TV.
Aug 19, 2007 | RCA 32V550T 32" TV
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
